Coreelec on Tanix TX3 or
Hello.Does coreelec runs ok with Tanix TX3?(Not mini L etc)I consider buying this tv box.Another alternative is Beelink Gt1 mini 2.Thanks.
If you mean the Tanix TX3 S905X3 4\32G it works very well with the CoreELEC nightly builds
CoreELEC-Amlogic-ng.arm-9.2-nightly_20200115-Generic.img.
.Make sure that you use this device tree(sm1_s905x3_4g.dtb)and rename it dtb.img.
tkanks very much.stream is ok with 1080p?also can you please test if audio bluetooth works?i am on a hard decision to decide to buy a new tv box…
1080p streeming ok and audio Bluetooth also works very well.
very nice!So not only S922 playes 1080p without issues.Maybe is time to replace my 2 years old TANIX TX92 with this.Btw,you found any working twrp?i want to unroot and then root with magisk…
As I said earlier it is a(Tanix TX3 S905X3 4\32G ) link(https://www.banggood.com/Tanix-TX3-S905X3-4GB-RAM-32GB-ROM-2_4G-5G-WiFi-Android-9_0-8K-TV-Box-Support-Voice-Control-p-1582529.html?rmmds=search&ID=533601&cur_warehouse=CN).It is not a S922 it is a S905X3 and I do not think is made by Tanix I think it is a clone but it works very well.
