This started happening a few days and now my remote doesn’t work. Nothing changed in my setup and I’m pretty sure my tv didnt update either. I’ve enabled/disabled CEC from inside Kodi, unplugged/plugged HDMI cable, tried a different cable but still get that same mesaage when i start Kodi
I can’t help but I get the same error message sometimes. I haven’t counted the exact number of times but it appears to happen about 1 in 3 reboots/power on. I can’t find a pattern as to what is causing it.
I did post a debug log in a previous thread a few days ago when it happened.
I’ll point out that I’m using a custom Amlogic-ng build which is the same as “coreelec-9.2” branch but with one kodi patch inserted into the build - that patch is mentioned here in a PR I submitted to Kodi a few weeks back. This patch removes one line of code from VideoPlayer.cpp. Link here:- https://github.com/xbmc/xbmc/issues/16390
This patch should have no impact on the CEC initialization error.
