I’m afraid there is no CI slot on KI Pro where you could insert the module.
I’m not aware of any USB solution yet so how you imagine the CoreElec could support the modules?
Of course not, you’re right.
I gave him incomplete information, apology.
I have 2 USB-Tuners with CI-Slot. These tuners work very well in ARM boxes as FTA, but because of the CI feature is not working, I’m obsessed with it.
My problem is, it would be great if I could use the CI feature.
Although I think you are going to use a legit smart card in your CI module, this isn’t a topic we could discuss here, because most probably a softcam would be involved in a possible solution.
Because this isn’t legal in some countries, we can’t talk about it.
Dear friend, I am aware of the sensitivity of the issue.
The subject has nothing to do with sfta* and Ocm, you can’t even take the card inside the CI and use it somewhere else, because it’s paired with the CI.
Okay, excuse me. I didn’t fully understand your request initially.
I’m sure the devs will take a look at it, but you should add some more information about your USB tuners including the exact brand/model.
