No, after the change, other interfaces are displayed in normal Chinese, only the information of this interface cannot be displayed
OK, let this interface be displayed in English
@ZZH
I’ll see how I can solve the problem.
Give me some time.
I will create a hotfix release later.
Please send me your translated .po file.
I tried the new version, and it’s awesome! ZZH can also delete OpenSansSemiCondensed font entry in the currently used font set within the Font.xml file, and that should work too.
I changed the font and it works. My translation is terrible. I don’t think it’s suitable for everyone. :rofl:
Np anyway, please send me the .po file and the font. I will add this later. :sweat_smile:
Too bad! Arctic Zephyr 2 : Resurrection is 100% the best one. I tried the AZR skin the other day, its just not the same. :frowning:
BUT. I totally understand you. I’m glad for the people that gets to enjoy your updates of the AZR.
For the font, I used the “InterCJKSC-Regular.ttf” font in the skin and renamed it to “OpenSans_SemiCondensed-Medium.ttf”
strings.po (53.3 KB)
Thank you!
I will add your translation later.
I will also solve the problem without replacing the font too. In correct way.
yes zh-cn Simplified Chinese
@ZZH
Please install this .zip and let me know if all is good now.
https://github.com/jamal2362/skin.arctic.zephyr.mod.cpm/archive/refs/heads/master.zip
No problem Display normal
@ZZH
Thank you for testing!
Works now :smiling_face:
For all others here:
I will upload another .zip file to github later, so you can have the codecs logos on top left if you want.
There will be two files to choose between. (top left or top right)
+1 to this one :wink:
I use PM4K Addons, unfortunately the dolby vision label is not in the right place and is visible for a short time.
Can you set the place and time for how long the DV label will be visible?
Its here
@borygo
It’s not the values, it’s the look, the PlayerProcessInfo screen looks better in AZR in my opinion.
I’m not trying to sound ungrateful about your work on AZ2R, it’s just a matter of taste :smiley:
Not possible sorry.
Please ask the PM4K developer why this is the case.
It seems that the video OSD is still visible when PM4K video OSD is active.
It’s up to him to fix this, not me.
No problem, I just mod those skins what I use, and made from my own, and look like, how the original base skin looks.
Dont want to made a mod, which is not this , also not want just copy paste from another skin.
I moved from the standard Estuary to your modified skin and it’s really good looking, nicely designed PlayerProcessInfo. Congratulations.
I currently have 17 installed. If I want to go to 18, do I need to settings/addon / install from zip or can I just overwrite the skin on the SD card with the content of your zip file ?
Both ways working.
Installing it with settings/addon / install from zip is the best way.
