Ok … on weekend i set my other 905x
Thx
Hi, on 905x no problems! Thx
Hallo,
Is ist possible to use my SD Card for Roms folder?
I installed CoreELEC on internal Storage.
All my retropie Roms are on the SD Card!
Second question: is it possible to add „dosbox“?
hi, above (first page) is the explanation to your question. You can put your roms on any external device… as you read this: „
but If you want to use an external HDD or a USB for your ROMS, make a directory called “roms” in the root of the USB device, then inside create an empty file called
sx05reroms, place your ROMS inside the corresponding folder (nes, snes, etc, etc.) then with the device plugged start the add-on.“
Okay
it only says USB and HDD
I give it a try
I am not sure where the SD card gets mounted. if it gets mounted under /media then you can follow the same instructions, if not, I might need to change the mounting script.
okay from SD Card it works, only problem is that i must insert it after boot.
SD Card is mount to media
other Question, were the hell is emustation here safe the pictures?.
on my sd card i got all pictures for the games
in “.emulationstation/downloaded_images”
but here i dont know were
i dont know if you compile it self.
but i got some Problem with PSX emulator:
Run Command is:
/storage/.kodi/addons/script.sx05re.launcher/bin/retroarch -L /storage/.kodi/addons/script.sx05re.launcher/lib/libretro/pcsx_rearmed_libretro.so /storage/roms/psx/Final Fantasy VIII.PBP
Emulator Output is:
Memcard 2: disabled
Starting PCSX-ReARMed
Running PCSX Version 1.9 (Feb 27 2019).
Init new dynarec
testing if we can run recompiled code…
test passed.
Mapped (RAM/scrp/ROM/LUTs/TC):
80000000/1f800000/1fc00000/08000000/f38d6000
no BIOS files found.
RGB565 supported, using it
plugin: plugins/builtin_gpu
plugin: plugins/builtin_spu
plugin: plugins/builtin_pad
Plugins loaded.
Could’t open ‘/storage/roms/psx/Final Fantasy VIII.PBP’ for reading: Value too large for defined data type
Error opening CD-ROM plugin!
Blockquote
here is the solution
During the build phase, make sure the flag -D_FILE_OFFSET_BITS=64
with SEGACD i have problems too,
Blockquote
Emulator Output is:
Sx05RE Run Log
1st parameter: GEN
2nd Parameter: /storage/roms/segacd/SonicCD.cue
3rd Parameter:
4th Parameter:
Run Command is:
/storage/.kodi/addons/script.sx05re.launcher/bin/retroarch -L /storage/.kodi/addons/script.sx05re.launcher/lib/libretro/picodrive_libretro.so /storage/roms/segacd/SonicCD.cue
Emulator Output is:
on retropie Sonic CD is working
There seems to be a patch in the works for PSX.
Sega CD I knew about, Picodrive had a bug that I already fixed, but I need to upload a new version, will try to do it soon.
I made so many changes to the core that the add-on script needs to be updated
and since its only me working on all of this, it could take some time, sorry.
I can try and upload the compiled cores with those fixes and see if it works for you.
I don’t think I understand what you mean, do you mean scraper images? those will always go to
/storage/.emulationstation/downloaded_images
or inside the roms folder
/storage/roms/[system]/downloaded_images
but I honestly don’t use the scraper included in ES as it doesn’t work 50% of the time.
It worked now with the picons.
In .emulationstation/gamelist
I copy it from Retropie and it works
Hello Friend, Your setup is amazing, thank you very much for everything, just a quick question, do you know how I can set up the controllers for the ppsspp emulator? I mean, it works great but after I restart the system all the settings get lost, I need to install or setup the controller again
It should automatically save it to /storage/.config/ppsspp/PSP/SYSTEM/ppsspp.ini
does that file exists?
logs would be helpful
by the way, i testet my PS3 Controller (bluetooth) but without your pre config it doesn’t work for me.
and
“Thanks you very much” for this Plugin. I uses my raspi for an Magic Mirror and saw your Plugin
all i need on one Machine
Thanks !!!
hi, is it possible to add “drastic” ?
it an Nintendo 2DS Emulator
Unfortunately no, Drastic is closed source and the version that exists for Raspberry Pi only works on Raspberry pi and was compiled by the author. Unless you can convince the author to compile version that works for Amlogic (or Gles2 in general) I don’t see it happening.
Mhh okay
Thanks. I just wait for the segacd and psx large file Patch. And it is Perfect for me
Although it seems this version MIGHT work , but I won’t include it unless I get proper permission to do so
you can try it yourself if you extract it using samba and test it by SSH
https://github.com/Retro-Arena/binaries/blob/master/odroid-xu4/drastic.tar.gz
if you don’t know how to, I can test it later.
I will give it a try
I‘m Linux specialist
PS3 NEEDS the workaround (EmuELEC: Retro Emulation Kodi Addon for CoreELEC!) , there is no other way (at the moment) to make it work on ES+RetroArch, I am more than happy to implement any ideas or fixes if other people provide them, but I won’t try to fix it myself anymore as it requires a lot of time I don’t really have right now.
