Reicast standalone works, reicast libretro works, but its too slow
Both of them depend on what rom you are loading, some of them work very good others lag.
/storage should be writable by default, there is nothing you need to change.
Re: Dreamcast on C2
Ahhh, it would appear there is no libretro core for Reicast in SX05RE. It has an .info file, but the .so file isn’t there. It doesn’t appear in core lists or core downloads, either. It does however run in ES just fine.
I might have not included it in the add-on version, since the libretro version is REALLY slow on Amlogic
what you are running is the standalone version, only accessible from Emulationstation or by SSH
There is no arcade file iv try nes still can’t use the controller
Since the controller works in the sx05re main menu but it’s not working with any emulator my be I need to try the method that is showing in the video below I’m at work now when I get back I will try
I give up I will buy a raspberry pi
Good luck,
Seems Wii remotes aren’t exactly easy things to work with on Pi either,
(https://pimylifeup.com/raspberry-pi-wiimote-controllers/). Arguably, the bluetooth stack on some Amlogic-based boards can be notoriously finicky (I’m looking at you, C2), but Wiimotes seem to be an additional problem all of their own. They don’t seem anywhere as easy to setup and use as Xbox 360, or even 3rd party PS3 controllers. RetroPie devotes several pages of non-trivial work to getting the damn things working with their OS:
In other words, the problem here is probably the Wiimote and not Sx05RE.
cheaper to just buy a new gamepad
but your choice!
Yeah, I would not recommend Wii-motes for retro emulation on these boxes.
Indeed, I love my Gamesir G3s’s; they set up like a breeze and use dongles, so I don’t have to deal with SBC Bluetooth woes. Comparatively, my knockoff PS3 controllers (on the same system, via Bluetooth) don’t have the same reliability and speed.
That looks like a nice gamepad!
They’re great! Excellent feel, build quality and responsiveness, and they’ve never dropped connection.
hi every one have any one try to play with a ps4 controller its not working i dont know why
sx05re.log
Blockquote
Sx05RE Run Log
1st parameter: ADVMAME
2nd Parameter: /storage/roms/mame-advmame/aof2.zip
3rd Parameter:
4th Parameter:
Run Command is:
/storage/.kodi/addons/script.sx05re.launcher/bin/advmame.sh /storage/roms/mame-advmame/aof2.zip
Emulator Output is:
ALSA lib /home/adamg/CoreELEC/build.CoreELEC-Amlogic.arm-9.0.1/alsa-lib-1.1.8/src/pcm/pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM sdl
es_log.txt
lvl2: EmulationStation - v2.9.0rp-dev, built Apr 12 2019 - 01:52:42
lvl2: Parsing XML file "/storage/.kodi/addons/script.sx05re.launcher/bin/resources/mamenames.xml"...
lvl2: Parsing XML file "/storage/.kodi/addons/script.sx05re.launcher/bin/resources/mamebioses.xml"...
lvl2: Parsing XML file "/storage/.kodi/addons/script.sx05re.launcher/bin/resources/mamedevices.xml"...
lvl2: Creating surface...
lvl2: Created window successfully.
lvl2: Added unconfigured joystick Wireless Controller (GUID: 050000004c050000c405000000010000, instance ID: 0, device index: 0).
lvl2: Checking available OpenGL extensions...
lvl2: ARB_texture_non_power_of_two: MISSING
lvl2: Loading system config file /storage/.emulationstation/es_systems.cfg...
lvl1: Error - folder with path "/storage/roms/amstradcpc" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/amstradcpc/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/amstradcpc/../comic_book.xml")
could not find file ""
lvl1: System "amstradcpc" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/arcade" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/arcade/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/arcade/../comic_book.xml")
lvl1: System "arcade" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/atari2600/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/atari2600/../comic_book.xml")
lvl1: System "atari2600" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/atari5200/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/atari5200/../comic_book.xml")
lvl1: System "atari5200" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/atari7800/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/atari7800/../comic_book.xml")
lvl1: System "atari7800" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/atari800" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/atari800/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/atari800/../comic_book.xml")
lvl1: System "atari800" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/atarilynx/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/atarilynx/../comic_book.xml")
lvl1: System "atarilynx" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/atarist" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/atarist/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/atarist/../comic_book.xml")
lvl1: System "atarist" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/coleco" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/colecovision/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/colecovision/../comic_book.xml")
lvl1: System "coleco" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/c64/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/c64/../comic_book.xml")
lvl1: System "c64" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/amiga/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/amiga/../comic_book.xml")
lvl1: System "amiga" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/pc/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/pc/../comic_book.xml")
lvl1: System "pc" has no games! Ignoring it.
lvl1: Unknown platform for system "famicom" (platform "famicom" from list "famicom")
lvl1: Error - folder with path "/storage/roms/famicom" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/famicom/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/famicom/../comic_book.xml")
lvl1: System "famicom" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/fds/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/fds/../comic_book.xml")
lvl1: System "fds" has no games! Ignoring it.
lvl1: Unknown platform for system "fba" (platform "fba" from list "fba")
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/fba/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/fba/../comic_book.xml")
lvl1: System "fba" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/gb/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/gb/../comic_book.xml")
lvl1: System "gb" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/gba/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/gba/../comic_book.xml")
lvl1: System "gba" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/gbc/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/gbc/../comic_book.xml")
lvl1: System "gbc" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/gameandwatch" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/gameandwatch/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/gameandwatch/../comic_book.xml")
lvl1: System "gameandwatch" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/intellivision" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/intellivision/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/intellivision/../comic_book.xml")
lvl1: System "intellivision" has no games! Ignoring it.
lvl1: Unknown platform for system "mame" (platform "mame" from list "mame")
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/mame/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/mame/../comic_book.xml")
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/msx/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/msx/../comic_book.xml")
lvl1: System "msx" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/neogeo/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/neogeo/../comic_book.xml")
lvl1: System "neogeo" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/ngp" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/ngp/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/ngp/../comic_book.xml")
lvl1: System "ngp" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/ngpc" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/ngpc/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/ngpc/../comic_book.xml")
lvl1: System "ngpc" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/nes/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/nes/../comic_book.xml")
lvl1: System "nes" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/n64/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/n64/../comic_book.xml")
lvl1: System "n64" has no games! Ignoring it.
lvl1: Unknown platform for system "openbor" (platform "ports" from list "ports")
lvl1: Error - folder with path "/storage/roms/openbor" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/ports/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/ports/../comic_book.xml")
lvl1: System "openbor" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/psx/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/psx/../comic_book.xml")
lvl1: System "psx" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/psp/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/psp/../comic_book.xml")
lvl1: System "psp" has no games! Ignoring it.
lvl1: Unknown platform for system "scripts" (platform "retropie" from list "retropie")
lvl1: Error - folder with path "/retropie/scripts/modules" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/retropie/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/retropie/../retropiemenu.xml")
lvl1: System "scripts" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/scummvm/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/scummvm/../comic_book.xml")
lvl1: System "scummvm" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/sega32x/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/sega32x/../comic_book.xml")
lvl1: System "sega32x" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/segacd/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/segacd/../comic_book.xml")
lvl1: System "segacd" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/dreamcast/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/dreamcast/../comic_book.xml")
lvl1: System "dreamcast" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/gamegear/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/gamegear/../comic_book.xml")
lvl1: System "gamegear" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/genesis" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/genesis/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/genesis/../comic_book.xml")
lvl1: System "genesis" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/mastersystem/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/mastersystem/../comic_book.xml")
lvl1: System "mastersystem" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/megadrive/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/megadrive/../comic_book.xml")
lvl1: System "megadrive" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/sg-1000" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/sg-1000/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/sg-1000/../comic_book.xml")
lvl1: System "sg-1000" has no games! Ignoring it.
lvl1: Unknown platform for system "sfc" (platform "sfc" from list "sfc")
lvl1: Error - folder with path "/storage/roms/sfc" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/sfc/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/sfc/../comic_book.xml")
lvl1: System "sfc" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/snes/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/snes/../comic_book.xml")
lvl1: System "snes" has no games! Ignoring it.
lvl1: Unknown platform for system "tg16" (platform "tg16" from list "tg16")
lvl1: Error - folder with path "/storage/roms/tg16" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/tg16/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/tg16/../comic_book.xml")
lvl1: System "tg16" has no games! Ignoring it.
lvl1: Unknown platform for system "tg16cd" (platform "tg16cd" from list "tg16cd")
lvl1: Error - folder with path "/storage/roms/tg16cd" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/tg16cd/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/tg16cd/../comic_book.xml")
lvl1: System "tg16cd" has no games! Ignoring it.
lvl1: Unknown platform for system "sgfx" (platform "sgfx" from list "sgfx")
lvl1: Error - folder with path "/storage/roms/sgfx" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/comic_book.xml")
could not find file "./art/system.png" (which resolved to "/storage/.emulationstation/themes/es-theme-ComicBook/art/system.png")
could not find file "./custom-collection/art/controller.png" (which resolved to "/storage/.emulationstation/themes/es-theme-ComicBook/custom-collection/art/controller.png")
could not find file "./custom-collection/art/system 3.png" (which resolved to "/storage/.emulationstation/themes/es-theme-ComicBook/custom-collection/art/system 3.png")
lvl1: System "sgfx" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/pcengine/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/pcengine/../comic_book.xml")
lvl1: System "pcengine" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/vectrex" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/vectrex/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/vectrex/../comic_book.xml")
lvl1: System "vectrex" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/videopac/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/videopac/../comic_book.xml")
lvl1: System "videopac" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/virtualboy" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/virtualboy/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/virtualboy/../comic_book.xml")
lvl1: System "virtualboy" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/wonderswan" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/wonderswan/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/wonderswan/../comic_book.xml")
lvl1: System "wonderswan" has no games! Ignoring it.
lvl1: Error - folder with path "/storage/roms/wonderswancolor" is not a directory!
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/wonderswancolor/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/wonderswancolor/../comic_book.xml")
lvl1: System "wonderswancolor" has no games! Ignoring it.
lvl1: Unknown platform for system "x68000" (platform "x68000" from list "x68000")
lvl1: Error - folder with path "/storage/roms/x68000" is not a directory!
lvl1: System "x68000" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/zxspectrum/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/zxspectrum/../comic_book.xml")
lvl1: System "zxspectrum" has no games! Ignoring it.
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/auto-allgames/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/auto-allgames/../comic_book.xml")
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/auto-favorites/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/auto-favorites/../comic_book.xml")
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/auto-lastplayed/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/auto-lastplayed/../comic_book.xml")
lvl1: Warning from theme "/storage/.emulationstation/themes/es-theme-ComicBook/custom-collections/theme.xml"
(from included file "/storage/.emulationstation/themes/es-theme-ComicBook/custom-collections/../comic_book.xml")
lvl2: Configuring device 0 (Wireless Controller).
lvl2: Mapping [Hat 0 up] -> Up
lvl2: Mapping [Hat 0 down] -> Down
lvl2: Mapping [Hat 0 left] -> Left
lvl2: Mapping [Hat 0 right] -> Right
lvl2: Mapping [Button 9] -> Start
lvl2: Mapping [Button 8] -> Select
lvl2: Mapping [Button 2] -> A
lvl2: Mapping [Button 1] -> B
lvl2: Mapping [Button 3] -> X
lvl2: Mapping [Button 0] -> Y
lvl2: Mapping [Button 4] -> LeftShoulder
lvl2: Mapping [Button 5] -> RightShoulder
lvl2: Mapping [Button 6] -> LeftTrigger
lvl2: Mapping [Button 7] -> RightTrigger
lvl2: Mapping [Button 11] -> RightThumb
lvl2: Mapping [Axis 1-] -> LeftAnalogUp
lvl2: Mapping [Axis 1+] -> LeftAnalogDown
lvl2: Mapping [Axis 0-] -> LeftAnalogLeft
lvl2: Mapping [Axis 0+] -> LeftAnalogRight
lvl2: Mapping [Axis 5-] -> RightAnalogUp
lvl2: Mapping [Axis 5+] -> RightAnalogDown
lvl2: Mapping [Axis 2-] -> RightAnalogLeft
lvl2: Mapping [Axis 2+] -> RightAnalogRight
lvl2: Mapping [Axis 2+] -> HotKeyEnable
lvl2: /storage/.kodi/addons/script.sx05re.launcher/bin/bash /storage/.emulationstation/scripts/inputconfiguration.sh
lvl2: req sound [basic.launch]
lvl2: (missing)
im back with news i use the video below and its working perfectly including the ps4 bluetooth controller the down side is some games didn’t download maybe because of broking link
remember to choose s905 device instead of android
update
create https://archive.org account
use setup wizard inside the Internet Archive ROM Launcher configuration and login with the account all the games will show up
any one have a controller input lag gust turn your tv into game mode
This has nothing to do with the add-on
Not for the add-on version been very busy trying to finish the standalone image, after that is done I will work on the add-on version.
You can always try the standalone version that I posted here:
https://forum.odroid.com/viewtopic.php?f=182&t=34355
I’ll take a look, cheers.
Matt
Can it be installed on SD card and dual boot with coreelec (on emmc)?
