sure. i put in my fba gamelist.xml to fba folder and snapshot image to snap folder.
(roms/fba/snap)
but didnt work only fba. it show me the only rom file name. maybe it would be loaded automatically.
in main menu, other setting/ parsa gamelist?
when i turn on this option, only show me the snes games.
when i turn off the option, it show snes, fba games but fba games with file name.
this is part of my fba list. same with snes’s form
Hi, one question. If I use the scrappers in your build, do they also dl snaps or only images?! I use a old software on windows, but this take for e.g. 100 games ca. 8-10 hours
snes works with korean.
if theme font doesnt support korean, it works with ㅁㅁㅁㅁㅁ.
so i changed the font and works well.
only fba game doesnt work.
when i put the same romfile in arcade folder.
es show me the mame category and internal game name(kof95>king of fighters ver02xxx etc…) not from the gamelist.xml
Hello all, I haven’t been as active on EmuELEC because I have an injury in my arm and I am limiting my keyboard time. I however have done a few changes and I think the add-on for the N2 is ready to be tested, I haven’t been able to test it myself, but if anyone is interested in testing it let me know, the add-on is to be run on top of CoreELEC for any system that is supported by it, so S905, S912 and S922 (Odroid N2). Just keep in mind that it might not even work at all, since like I mentioned I haven’t been able to test it.
It has also changed its named from Sx05RE to EmuELEC (even the add-on version, for simplicity sake and to avoid confusion) so if you have the old Sx05RE add-on you are going to have to remove it and reinstall this one, sorry for that
Doesn’t crash when going back to the main menu on the n2 anymore.
However I don’t have ‘exit to kodi’ option in the shutdown menu anymore. Have to reboot the whole thing to get back into kodi.
boa noite, efetuado testes numa box s905 x96 mini portanto funciona corretamente emuelec testei todos emuladores o emulador FBA e MAME todos os jogos cps1 e cps2 e konami o jogo entra e não funciona o controle os botoes, testei tambem emuelec script no coreelec e funciona somente na mini x96 não funciona deve estar desatualizado o script
good night, done tests in a box s905 x96 mini so it works correctly emuelec tested all emulators emulator FBA and MAME all games cps1 and cps2 and konami the game enters and does not work the control the buttons, I also tested emuelec script in coreelec and it works only on mini x96 does not work should be outdated the script
