EmuELEC: Retro Emulation Kodi Addon for CoreELEC!
is it possible to “exit to kodi” via ssh command?
i always use reboot but then it restarts the box compliteley
and can i use the N2 Version for GT King also ?
bug on 2.6 addon: laks “quit to kodi” option
workaround: “quit to retroarch” starts Kodi
Yes, the one named “Amlogic-ng” works on all S922x
Wanna go back to Kodi via ssh? Depending on which UI you use:
killall emulationstation
or
killall retroarch
Works for me.
Edit: Fixed incorrect command.
If you use SSH to do all of that you will need to start kodi after any of those commands
systemctl start kodi
The question is why ? you should not need to do this.
if emulationstation hangs… cant get back to menue if not selecting a LIBRETRO_* Emu
Not sure I understand what you mean, sorry.
@shanti
if i start a PSP game with PPSSPSA Emu i cant go to Setting GUI with Hotkey on my controller
and i miss a good scaler on the PSX Emu
You should be able to use a keyboard to configure your pad, but it should already be setup unless its an obscure gamepad?
Does anybody use Amiga (Comodore-Amiga) emulator ?
Which one works, “game.libretro.uae” or “game.libretro.uae4arm” ?
Is the latter only for RPi or works also on Amlogic SoC ?
what about Dosbox include ?
N64 performance on Paralell is very poor, even on 320x240 (KI Pro) what are the best settings?
Not sure what CPU the Ki Pro has but N64 is poor in general, your best bet is to use Mupen64plus-nx as the core and it depends a lot on the game you want to run, for example Mario Kart runs really good while Resident Evil 2 is unplayable
They both should work if setup correctly, you need the correct kickstart in /storage/roms/bios
I did all that, although not sure about (re)naming bios kickstart roms.
All I get is “game.libretro.uae encountered internal error” or something like that, and none game starts. I have correct roms (checked MD5) for Amiga 500, 600 and 1200. Games that don’t work are all for Amiga 500/600…
You can check in Retroarch in the “core info” screen what bios/kickstarts you need
Will do that, thnx.
There is no any info concerning “kickstart” in “core info” screen, or anywhere else…
