forgot: GREAT WORK !!!
1.- judging by the name of the “sx05reroms” file (since you didn’t provide any logs) you are using an old version that is not going to work as expected for 9.2.0 you need to use the test version for “nightly” it has been discussed before a few messages back), I am sure if there was a problem with the n64, gba and dc games I would get a lot of messages, so I assume your folder names are probably not correct, or there is something else on your setup.
2.- See above, old version on new CE = problems
@filenames: it was a CaSe SenSItive issue .
@Logs: where do I find the logs (/storage/…) you need for further analysis ?
@old version: I use the v2.5 [script.sx05re.launcher-2.5.zip] and CoreElec 9.2.0 stable (no nightly)
thanks for the quick reply!
Like I said, it has been discussed a few messages back.
Using the new 2.7.1 addon version on s905
new bug : trying to enter the “emuelec option” does nothing…where you select which core you will be using.
2.7.1 Addon on Odroid-N2 working good so far. Have not done a lot of testing, but just want to thank you Shanti.
I think I know the issue will try to upload a new version, or at least a new emulationstation bin
Can you replace the emulationstation binary with this one ? https://1drv.ms/u/s!AhB0moRaeC4QggQTXZrTzwtD-XQX?e=LlIHPf
That worked!
New bug : o2em_libretro.so core for odysee was missing from your build.
Fix : I put the one from the nightlies in :
https://buildbot.libretro.com/nightly/linux/armhf/latest/o2em_libretro.so.zip
It works great now!
@shanti is it to much to ask that you announce new versions/updates here on the CE forum so that we all know that an update is available ?
With new version on N2 “EmuELEC” settings from Main Menu is not accessible. Nothing happens when I try to select this option. (Same as @sammaz reported for S905)
Can I use the same version of “emulationstation binary” as you suggested to @sammaz for S905 ?
Not sure what you mean all releases have been announced here, even the test releases.
Yes, the same binary can be used.
I will make sure to include that core on the next release, which should be soon, just need to test that no bugs like the ES one happen again
Sorry, did not see your post announcing 2.7.1 update…
OK thnx, will try with this new binary.
With this new binary it works OK on N2 (CE 9.2)
Hi, How i can configure overlays/bezels ?
This is something I haven’t thought of dealing with before, Bezels and splash use /tmp to store the files, but on the addon is hard to acces /tmp since there is no Samba share for it, will need to change the paths for this to work or use a symlink. Thanks for remind me.
drastic configuration is not working with the new VIM3…
setterm 16 i have no picture…
CoreELEC uses a different alpha channel in the Kernel for compatibility with Kodi, some emulators like, PPSSPP, OpenBOR, DosBoxSDL2 and probably drastic will not work unless you uses setres.sh 16, but even then, it might not work, this is something that I can’t control. Because of this there are so many problems with standalone emulators and I do not have enough knowledge for a proper fix/workaround.
S905 also has the same problem but it seems setrest.sh works better there than on the S922/A311D
Any new news on the AddOn-Update?
(.zip file, not into compiling myself?)
