I currently have the Ugoos dual boot image installed with CoreElec installed. How do I change this to the recommended eMMC dual boot image?
I have read and read the eMMC guide but I am not sure what I should do?
Appreciate any input.
What I did was using the amlogic image burning tool, and a USB-A 3.0 OTG cable. Grabbed the regular (not dce) 0.5.4 image supplied by Ugoos. Used that to flash the Ugoos (following instructions provided in the tool, give it a good 5 minutes). That letās you basically go back to stock. Then proceeded with the ceemmc tool.
How do you change from HS200 to HS400? I see the option, to change, it asks me for the code, something like '52, I insert it but it goes back to HS200. Does the ā stand for something? Newbie here
for a non it guy like me - who will hopefully see a Linux first time in 1h - this whole journey is a bit thrillingā¦
Iām crossing all my fingers that I donāt have to ask for help in 5min again⦠Iāve not really understood the tree topic and the move to internal emmc but I will try!!
