Help, support CPM build
Go back to using the stock CE. Find out what TV you have.
My TV is a TCL 55R617 it supports Dolby Vision.
Topic closed for now until we decide how to proceed.
The people here have several contributions to a multitude of projects and are really interested in helping out when needed.
I don’t see the problem IMHO. You’ve created a sub forum for Unsupported SW → Community Projects. The cpm build is a community project, but now you’re closing all topics related to it? I’m not sure why cpm needs to be treated with such hostility?
The problem is we are in responsible, also when we write it’s “unsupported”.
And we are already on limits and are not able to handle items about community builds where we are out of control by the way.
So the way is that cpm (who is still here with a hidden pseudonym user) to create his own platform to handle issues with users and his build.
Can this not be discussed elsewhere?
I think CPM build conversations are wrong here.
I am just providing some skins, nothing more.
Whether someone uses it or not is actually of less interest to me.
For me, I have done what I wanted to do, because I will use the CPM builds for many years, even if it is an old build. That shouldn’t change the local media playback if the build is newer or older…
It doesn’t have to be a new build (not needed).
Can you provide an example where CE devs have been responsible for a cpm build item?
No one is asking you guys to, not one CE team member even needs to open this thread. The conversation was entirely fine before it was locked, it was just members helping other members and wasn’t off-topic whatsoever.
But it seems that even seeing any mention of cpm on this forum is enough to upset some team members. I just can’t understand why… especially when VS10 isn’t available in CE at all. Just let people watch how they want to watch.
I fully agree
It’s because we need to read and check everything written, also when it’s not of interests at all.
Also we need to filter out new users request support for what we are not responsible. And this multiple times each day…
Fact is this here is the CE forum, not cpm ones.
And it’s also fact the author did decline multiple times any requests to help or to give support.
So why should we provide a platform for free and maintained for him? It’s also fact he registered 3 users to read incognito on the forum and so he thinks he is out of responsibility of his public available builds.
So solution is: he make a own platform like other forks do as well or he stop and remove his builds and keep them personal.
I dont care much about all this drama but I personally use the CPM builds only for the cool OSD information. The day you add it (if it ever happens) to the nightlies, I’ll be happy to switch.
For me it’s the same. The only thing that convinces me to use the cpm build, are the info displayed in the playerprocessinfo. Some time I use SDR to DV but the day when the official branch will display all that info for me will be a good day.
Ok, then it’s all said and we lock down stuff about cpm.
All can contact him about support or if he will please open a own platform for his builds.
Continue here: cpm-code/xbmc ¡ Discussions ¡ GitHub
I cannot post in the Help & Support section, so I’ll post this here instead.
I just encountered an issue with the Ugoos AM6B Plus not being able to properly play DV Profile 5 content from Amazon Prime Video specifically using CoreELEC. The video is purple and pink during playback and Dolby Vision does not get enabled on my TV. DV Profile 8 from Amazon seems to playback just fine with no issues. I have an LG G4 television.
DV Profile 5 playback seems to be fine with every other streaming service except for Amazon from my experience so far. I’ve posted the MediaInfo of the video and Kodi debug log below.
MediaInfo
Kodi.log
Unsupported cpm build, closed.
Go there: cpm-code/xbmc ¡ Discussions ¡ GitHub
Hi!
Anyone have any idea why the wifi keeps going down? I’ve tried everything, but nothing works. The whole interface disappears, only if I turn off the wireless access on and turn it back on does it help.
rev d
cpm a11
I’ve tried several NG nightly builds, all of them have the same issue.
It works perfectly well with an external AC wifi dongle (TP-Link T3U Plus).
Sorry for my English, I use a translator.
Here is the output of dmesg:
[ 3684.296395@3]- [dhd] CFG80211-ERROR) wl_cfg80211_hang : In : chip crash eventing, reason=0x8002
[ 3684.296412@3]- [dhd] ndev->name : wlan0 dev close
[ 3684.296429@3]- [dhd] [wlan0] wl_cfg80211_disconnect : Reason 3, act 1, bssid c8:7f:54:bc:08:9c
[ 3684.296446@3]- [dhd] dhd_query_bus_erros: FW TRAP has occurred, cannot proceed
[ 3684.296450@3]- [dhd] [Repeats 10 times]
[ 3684.296456@3]- [dhd] CFG80211-ERROR) wl_cfg80211_disconnect : error (-19)
[ 3684.297295@3]- [dhd] [wlan0] dhd_pri_stop : tx queue stopped
[ 3684.297303@3]- [dhd] [wlan0] dhd_stop : Enter
[ 3684.297307@3]- [dhd] dhd_stop: ######### called for ifidx=0 #########
[ 3684.297332@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297339@3]- [dhd] CFG80211-ERROR) wl_cfg80211_bss_isup : 'cfg bss -C 0' failed: -19
[ 3684.297343@3]- [dhd] CFG80211-ERROR) wl_cfg80211_bss_isup : NOTE: this ioctl error is normal when the BSS has not been created yet.
[ 3684.297348@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297352@3]- [dhd] CFG80211-ERROR) wl_cfg80211_clear_security : wsec clear failed
[ 3684.297355@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297358@3]- [dhd] CFG80211-ERROR) wl_cfg80211_clear_security : auth clear failed
[ 3684.297361@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297364@3]- [dhd] CFG80211-ERROR) wl_cfg80211_clear_security : wpa_auth clear failed
[ 3684.297903@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297912@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297917@3]- [dhd] CFG80211-ERROR) wl_cfg80211_update_power_mode : error (-19)
[ 3684.297924@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.297983@3]- [dhd] CFGP2P-ERROR) wl_cfgp2p_disable_discovery :  do nothing, not initialized
[ 3684.298015@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.298021@3]- [dhd] CFG80211-ERROR) wl_dongle_down : WLC_DOWN error (-19)
[ 3684.298026@3]- [dhd] dhd_stop: making dhdpub up FALSE
[ 3684.298037@3]d [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 3 -> mode 0
[ 3684.298039@3]d [dhd] dhd_tcpack_suppress_set: TCPACK_INFO_MAXNUM=40, TCPDATA_INFO_MAXNUM=40
[ 3684.298078@3]- [dhd] [wlan0] wl_android_wifi_off :  g_wifi_on=1 force_off=1
[ 3684.298096@3]- [dhd] dhd_bus_devreset: == Power OFF ==
[ 3684.298100@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.298104@3]- [dhd] dhdpcie_advertise_bus_cleanup: DB7 Not sent!!!
[ 3684.298127@3]d [dhd] dhd_bus_stop: making DHD_BUS_DOWN
[ 3684.298154@3]- [dhd] dhd_dpc_kill: tasklet disabled
[ 3684.304650@3]d [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[ 3684.304664@3]- [dhd] dhd_bus_devreset:  WLAN OFF Done
[ 3684.304672@3]- [dhd] dhd_os_send_hang_message: dhd_stop in progress
[ 3684.304677@3]- [dhd] dhd_net_bus_devreset: retrun error due to query errors
[ 3684.304682@3]- [dhd] dhd_net_bus_devreset: dhd_bus_devreset: -1
[ 3684.304687@3]- [dhd] wifi_platform_set_power = 0, delay: 0 msec
[ 3684.304692@3]- [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3684.304695@3]- [dhd] [wlan0] wl_android_wifi_off : out
[ 3684.304734@3]- [dhd] [wlan0] dhd_stop : Exit
I have two set-top boxes, one is A311D-K and the other is S905X4-K. Under the same projector and the default settings of CE, the picture of A311D-K is very clear and clean. The picture output of X4-K is a bit white and the picture brightness is a little higher. What’s more interesting is that using the machine of X4-K under the CPM build and without enabling Dolby Vision, the “woman” can still be seen on the non-Dolby display device.
Forrest Gump P7 under A311D-K
Forrest Gump P7 under S905X4-K
The woman
