Very sad, But it is your decision… Happy you will not leave this community.
Thanks Great Man
Picked up a copy and it crashes out on my Ugoos.
Looks like something to do with subtitles, last thing is does before crashing for me is:
2024-09-19 20:04:21.874 T:4326 info : CDVDSubtitlesLibass: Initializing ASS library font settings
Hope that helps narrow things down.
@cpm, I want to thank you for all of your time, dedication, and results on your builds. You truly delivered exceptional features/functionality in such a short time. Like I mentioned before, the CE team has done and is doing a great job but there is space for more than one or two heroes. We need more of them, not less. I am very sorry for the time that you have lost with your family and I fully understand your position.
Unfortunately, the overall forum/thread community (not you or the CE developers) with the best of intentions to have your build results merged with the main line CE development, raised enough pressure/temperature and have roasted the goose. As the final line reads “Those who have plenty want more and so lose all they have.”
@cpm, thanks for your hard working. spending your free time to solve issue’s of other people, is noble.
thanks for your time and efforts. you can now enjoy your free time and family…
for now my question/ humble request to other users:
can somebody upload any of the builds of cpm? i got my self build T6A, T6A2, T7 and T8.
so, i need builds from T1 till T6.
i will be even satisfied with temporary links. after my download, you can delete/remove your link/file.
i am trying to collect all builds of cpm
I got saved T3, T4A, and T6, which do you want besides T6?
Anyway, here are all 3 of them zipped
I have also saved FC10, FC11, FC12 and FC15 versions that came before T versions, if you are interested to archive them.
thanks for your efforts,
you can remove your T3, T4A, T6 links. i got them.
i would like to have all the rest which i dont have.
what i now have are:
T3,T4A, T6, T6A, T6A2, T7, T8.
i would like to have the rest of releases.
Here is the rest that I have saved.
Basic question: if I have an LG G4 and don’t have any HDR10+ content, is there any reason for me to mess with CPM’s build? What would the benefits be? Thanks!
Would recommend you stick with the CE stable or maybe nightly if you have an issue and just enjoy that.
If I upgrade from CPM-build to CE stable or nightly, will the upgrade work correctly? Will the settings be preserved, so I don’t have to install everything from scratch?
yes, just put CE stable or nightly into update folder then restart device.
I can seek blu-ray ISOs by using the channel up/down commands on the remote. But not using the DirectionLeft/Right commands. I can’t control the seek and it feels random so I assume it’s looking for I-frames?
There is no option with chapter or normal seek. Try another sample or share a short sample.
It’s the Universal Studios 4K discs. When I try to seek left/right it brings up the Universal pop up menu. Only the channel up/down commands on the remote works and they do what looks like I-frame seeking.
I tried with Estuary and I get the same results. The issue happens for me with some Universal 4k discs. The blu-ray menu for Gladiator 4K is completely broken for me.
You talk about different items. It was a fix about seek, not about bluray menu in any way. Please contact the author of the bluray menu, not CE.
DVD menu handling is still faulty in Kodi so why BD menu should work better?
And I guess it will never becomes better as it’s open source.
Just installed latest CPM mod and that fixes most of the Gladiator 4K ISO issues. The seek controls still bring up the Universal pop-up menu and the only way to seek is still to use the channel up/down buttons. But at least the menu is now working properly allowing me to select which version of the movie I want to watch.
OK it looks like what actually (kind of) fixes the issues is to turn off Dolby Vision. Then the Gladiator menus work. When I first installed CPM DV was off by default.
How the fix should be inside the cpm build when the last build was BEFORE the fix?
I will move this than to the correct place…
Doesn’t matter if CPM is on or not. Turning off Dolby Vision is what actually fixes the issues with Gladiator 4k blu-ray menus. If you read the post following that one you will have seen this update. So this post is now in the wrong place.
