Yes, AV1 is supported.
looks like a broken HDMI signal to me (but i am no expert).
but would advice to check the connections or check the box with another cable / screen.
maybe it has a problem with the resolution or wrong Hz?
could it be that smb hasn’t worked since the last 3 nightlies? I can no longer connect to the box via smb. there is always an authorization error message. with version from 090523 it still worked. SSH or sftp works normally.
It is working for me by using SMB, yesterday still was, after installing the last update that was offered to me.
Sehr seltsam… Mit meinem SD Backup vom 09.05 geht’s , mit aktueller Version nicht , obwohl alles in den settings gleich ist .
Oh sorry… Forgot to write in English…
Strange … With backup SD card from 090523 it works fine with same settings as the latest one …
Does anyone know why I need to hold down the Home+Back buttons on my R21 remote every time I reboot my HBR4K+ to connect it over Bluetooth?
Same here … So I decided to use IR mode. And so I have the option to use the volume keys for my Marantz avr too.
And I think for suspending the only way is to mount and use internal storage… But I don’t know for sure…
It is one of the mystery issues. Sometimes BT works and sometimes not. Mostly not ![]()
Is there a fix for the storage disconnecting and everything freezing after suspending?
That’s too bad. I find it really convenient having a working Bluetooth remote so I can put the Playback Device away in my media console and not need line-of-sight to it. Bluetooth also just tends to be significantly more responsive (even when communicating over CEC). Any chance of this being fixed at some point?
USB booting when USB get disconnected on suspend/resume is tricky and unsupported.
But you can try partial install to eMMC as described here. Use at your own risk !
I can’t understand why it’s a major annoyance to press 2 buttons to make the remote work. It would be better to not need it but it’s not that bad.
Because my family gets frustrated and doesn’t want to use it.
Do any of these Homatics-like boxes have an SD-card slot that you can install to that does allow eMMC booting?
Use CEC or IR
Yes and no
according to this:
Chart (Source)
the RockTek G2 has one but since i did not find a seller in the EU i can not tell if it is bootable
I have a question regarding the booting:
(i am testing Audio and have the feeling that Auro3D sources are not correctly passed through by Kodi or Elec. )
Is there a way to get back into the AndroidTV or to reboot to Android from Kodi/Elec?
with kind regards
We know, but what the user wants is boot from emmc and that’s not related to having a microSD slot or not. Booting from emmc would wipe android.
