Add this to advancedsettings.xml and try it.
<advancedsettings>
<gui>
<algorithmdirtyregions>0</algorithmdirtyregions>
</gui>
</advancedsettings>
<advancedsettings>
<gui>
</gui>
</advancedsettings>
It will go to CoreELEC. In the CoreELEC power menu you can chose reboot from emmc to go to Android.
only on nightly tho not on stable ![]()
How many time are we going to have this type of comment? Team CoreELEC only had samples after stable, DV is only supported in CE21 based on Kodi 21 so there’s only Alpha build available.
You make it sound we break everything in every other nightly.
sorry i mean no offence ![]()
just to clarify since (for example i could not find the button described because i was on stable)
My personal experience with nightly is very short (a week so far) so i cant make any judgment regarding stability.
From reading this thread (i did not yet read any further in this forum) there seam to be a few ppl with problems in nightly for example yesterday from FoLeY. But again i cant comment on them since i am no expert.
My intent is to make things clear for others so there are no misunderstandings. (just from my personal experience regarding documentation [writing and following] clarity is the key to understanding → like pointing out differences)
Currently there is no stable for Homatics, Kodi Omega is not stable either. First DV version didn’t have that reboot from emmc option.
but what is the stable which you can download on the website ? O.o
Issue with MCH HDMI output.
After the last update to CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20230610 the MCH PCM Audio won’t work. My Denon x4500h shows only stereo. The same behaviour with CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20230606.
With CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20230603 the PCM MCH output was fine.
Do I miss something e.g. a new setting or is really something broken?
I can’t find the CoreELEC-Amlogic-ne.aarch64-21.0-Omega_nightly_20230603.tar file in the archive
https://relkai.coreelec.org/?dir=Amlogic-ne/ce-21/archive
So where can I download the 20230603 nightly?
It is gone.
Is there another option to get the MCH PCM output back?
I think it will get fixed back eventually.
OK, Thanks.
Meanwhile I will use converting HiRes MCH PCM to DD 5.1…
I can also confirm multichannel PCM not working properly. Example being films on bbc1 HD that are broadcast in AAC 5.1
Do we know the last version when MCH output was working?
Also, do we have an idea of when it’ll be fixed? ![]()
I’m sure it worked with the nightly version Omega_nightly_20230603
It may have, last 2 builds definitely not though. I didn’t do extensive testing but it seemed like only left and right channels were being output with no center channel etc.
Test it: Unique Download Link | WeTransfer
Loving the experience with this box on the nightly. Thanks CE team!
How do i get the remote working in IR mode? Mine is the Dune Homatics box. Black one.
Try this: Homatics Box R 4K Plus - #620
2023-06-12 16:34:11.425 T:1422 debug <general>: CDVDClock::SetSpeedAdjust - adjusted:0.000000
2023-06-12 16:34:11.425 T:1424 debug <general>: CAMLCodec::SetSpeed, speed(0)
2023-06-12 16:34:11.496 T:970 debug <general>: CActiveAESink::OpenSink - trying to open device ALSA:surround71:CARD=AMLAUGESOUND,DEV=0
2023-06-12 16:34:11.497 T:970 info <general>: CAESinkALSA::Initialize - Configure simple control for "AUGESOUND"
2023-06-12 16:34:11.497 T:970 info <general>: CAESinkALSA - Use card "hw:0" and set codec format "8 CH PCM"
2023-06-12 16:34:11.497 T:970 info <general>: CAESinkALSA - Set Spdif to HDMITX to "Spdif_b"
2023-06-12 16:34:11.497 T:970 info <general>: CAESinkALSA - Set codec for "Audio spdif_b format"
2023-06-12 16:34:11.497 T:970 info <general>: CAESinkALSA - Set codec for "Audio spdif format"
2023-06-12 16:34:11.497 T:970 info <general>: CAESinkALSA::Initialize - Attempting to open device "surround71:CARD=AMLAUGESOUND,DEV=0"
2023-06-12 16:34:11.502 T:970 info <general>: CAESinkALSA::Initialize - Opened device "surround71:CARD=AMLAUGESOUND,DEV=0"
2023-06-12 16:34:11.502 T:970 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-06-12 16:34:11.502 T:970 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-06-12 16:34:11.502 T:970 debug <general>: CAESinkALSA::InitializeHW - Request: periodSize 2400, bufferSize 9600
2023-06-12 16:34:11.530 T:970 debug <general>: CAESinkALSA::InitializeHW - Got: periodSize 2400, bufferSize 9600
2023-06-12 16:34:11.530 T:970 debug <general>: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
2023-06-12 16:34:11.530 T:970 debug <general>: CAESinkALSA::GetChannelLayout - Input Channel Count: 6 Output Channel Count: 6
2023-06-12 16:34:11.530 T:970 debug <general>: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR, FC, LFE, BL, BR
2023-06-12 16:34:11.530 T:970 debug <general>: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR, LFE, FC, BL, BR (ALSA: FL FR LFE FC RL RR)
2023-06-12 16:34:11.531 T:970 debug <general>: CActiveAESink::OpenSink - ALSA Initialized:
2023-06-12 16:34:11.531 T:970 debug <general>: Output Device : AML-AUGESOUND
2023-06-12 16:34:11.531 T:970 debug <general>: Sample Rate : 48000
2023-06-12 16:34:11.531 T:970 debug <general>: Sample Format : AE_FMT_S24NE4
2023-06-12 16:34:11.531 T:970 debug <general>: Channel Count : 6
2023-06-12 16:34:11.531 T:970 debug <general>: Channel Layout: FL, FR, LFE, FC, BL, BR
2023-06-12 16:34:11.531 T:970 debug <general>: Frames : 2400
2023-06-12 16:34:11.531 T:970 debug <general>: Frame Size : 24
2023-06-12 16:34:11.532 T:969 debug <general>: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
2023-06-12 16:34:11.533 T:1423 info <general>: Skipped 1 duplicate messages..
2023-06-12 16:34:11.533 T:1423 debug <general>: CDVDAudio::Pause - pausing audio stream
2023-06-12 16:34:11.539 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:46477 dts:642.967 pts:643.367 dur:40.000ms, clock:634.547 level:97
2023-06-12 16:34:11.539 T:1422 debug <general>: CVideoPlayer::HandleMessages - player started 1
2023-06-12 16:34:11.539 T:1411 debug <general>: OnAVChange: CApplication::OnAVChange
2023-06-12 16:34:11.539 T:1422 debug <general>: CDVDClock::SetSpeedAdjust - adjusted:0.000000
2023-06-12 16:34:11.539 T:1424 debug <general>: CAMLCodec::SetSpeed, speed(1000)
2023-06-12 16:34:11.539 T:1422 debug <general>: VideoPlayer::Sync - Audio - pts: 634.554, cache: 0.516, totalcache: 0.800, packets:378 level:97
2023-06-12 16:34:11.539 T:1422 debug <general>: VideoPlayer::Sync - Video - pts: 635.247, cache: 0.050, totalcache: 0.100, packets:201 level:98
2023-06-12 16:34:11.539 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(635146578.000000)
2023-06-12 16:34:11.539 T:1424 debug <general>: CVideoPlayerVideo - OUTPUT_AGAIN - vfmt, interlace should be checked.
2023-06-12 16:34:11.540 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::DEMUXER_PACKET - checking interlace vfmt: null
2023-06-12 16:34:11.540 T:1411 debug <general>: OnAVStarted: CApplication::OnAVStarted
2023-06-12 16:34:11.541 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:20358 dts:643.007 pts:643.207 dur:40.000ms, clock:635.148 level:97
2023-06-12 16:34:11.541 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:11680 dts:643.047 pts:643.127 dur:40.000ms, clock:635.148 level:98
2023-06-12 16:34:11.541 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:6552 dts:643.087 pts:643.087 dur:40.000ms, clock:635.149 level:99
2023-06-12 16:34:11.542 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:7215 dts:643.127 pts:643.167 dur:40.000ms, clock:635.149 level:99
2023-06-12 16:34:11.544 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:14642 dts:643.167 pts:643.287 dur:40.000ms, clock:635.151 level:99
2023-06-12 16:34:11.553 T:1003 debug <general>: script.skin.helper.widgets --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {"item":{"title":"The Last Stand","type":"movie"},"player":{"playerid":-1,"speed":1}}
2023-06-12 16:34:11.554 T:1003 debug <general>: script.skin.helper.widgets --> Kodi_Monitor: sender xbmc - method: Player.OnAVStart - data: {"item":{"title":"The Last Stand","type":"movie"},"player":{"playerid":-1,"speed":1}}
2023-06-12 16:34:11.555 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:7865 dts:643.207 pts:643.247 dur:40.000ms, clock:635.162 level:98
2023-06-12 16:34:11.557 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::DEMUXER_PACKET - checking interlace vfmt: null
2023-06-12 16:34:11.572 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:106ms pts:635.287 Clock:635.180 Level:0
2023-06-12 16:34:11.574 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:145ms pts:635.327 Clock:635.181 Level:1
2023-06-12 16:34:11.584 T:1423 debug <general>: CDVDAudio::Flush - flush audio stream
2023-06-12 16:34:11.585 T:1423 debug <general>: CDVDAudio::Resume - resume audio stream
2023-06-12 16:34:11.589 T:969 debug <general>: ActiveAE - start sync of audio stream
2023-06-12 16:34:11.590 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:169ms pts:635.367 Clock:635.197 Level:2
2023-06-12 16:34:11.592 T:952 debug <general>: Activating window ID: 12005
2023-06-12 16:34:11.593 T:952 debug <general>: ------ Window Deinit (MyPVRRecordings.xml) ------
2023-06-12 16:34:11.594 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:204ms pts:635.407 Clock:635.202 Level:3
2023-06-12 16:34:11.597 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:7763 dts:643.247 pts:643.327 dur:40.000ms, clock:635.204 level:97
2023-06-12 16:34:11.597 T:952 debug <general>: FreeVisualisation() done
2023-06-12 16:34:11.601 T:1422 info <general>: Skipped 1 duplicate messages..
2023-06-12 16:34:11.601 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:41280 dts:643.287 pts:643.567 dur:40.000ms, clock:635.208 level:97
2023-06-12 16:34:11.602 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:18373 dts:643.327 pts:643.487 dur:40.000ms, clock:635.209 level:97
2023-06-12 16:34:11.603 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:11444 dts:643.367 pts:643.447 dur:40.000ms, clock:635.210 level:98
2023-06-12 16:34:11.603 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:8112 dts:643.407 pts:643.407 dur:40.000ms, clock:635.211 level:99
2023-06-12 16:34:11.606 T:952 debug <general>: ------ Window Init (VideoFullScreen.xml) ------
2023-06-12 16:34:11.608 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:231ms pts:635.447 Clock:635.215 Level:4
2023-06-12 16:34:11.608 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:7479 dts:643.447 pts:643.527 dur:40.000ms, clock:635.215 level:99
2023-06-12 16:34:11.610 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:269ms pts:635.487 Clock:635.217 Level:5
2023-06-12 16:34:11.613 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:65435 dts:643.487 pts:643.607 dur:40.000ms, clock:635.220 level:99
2023-06-12 16:34:11.618 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:301ms pts:635.527 Clock:635.225 Level:6
2023-06-12 16:34:11.619 T:952 info <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 25.000, 3D: false
2023-06-12 16:34:11.619 T:952 debug <general>: [WHITELIST] Using the default whitelist because the user whitelist is empty
2023-06-12 16:34:11.619 T:952 debug <general>: [WHITELIST] Searching for an exact resolution with an exact refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] No match for an exact resolution with an exact refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] Searching for an exact resolution with double the refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] No match for an exact resolution with double the refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] Searching for an exact resolution with a 3:2 pulldown refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] No match for a resolution with a 3:2 pulldown refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] Searching for a closest resolution with an exact refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] No match for a closest resolution with an exact refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] Searching for a closest resolution with double refresh rate
2023-06-12 16:34:11.620 T:952 debug <general>: [WHITELIST] Matched a closest resolution with double refresh rate 3840x2160 @ 50.00 - Full Screen (23), penalty 3000
2023-06-12 16:34:11.621 T:952 info <general>: Display resolution ADJUST : 3840x2160 @ 50.00 - Full Screen (23) (weight: 0.000)
2023-06-12 16:34:11.622 T:952 debug <general>: AMLUtils::aml_get_drmDevice - drm devices found: 1
2023-06-12 16:34:11.623 T:952 debug <general>: AMLUtils::aml_get_drmDevice_connector - devices have 2 connector(s)
2023-06-12 16:34:11.623 T:952 debug <general>: AMLUtils::aml_get_drmDevice_encoder - connector[70] is connected with 1 encoder(s)
2023-06-12 16:34:11.623 T:952 debug <general>: AMLUtils::aml_get_drmDevice_crtc - check 1 crtc(s)
2023-06-12 16:34:11.623 T:952 debug <general>: AMLUtils::aml_get_drmDevice_mode - current mode: 2160p60hz
2023-06-12 16:34:11.624 T:952 debug <general>: CWinSystemAmlogicGLESContext::CreateNewWindow: m_bWindowCreated: true, frac rate 0(0), cs: 3(3), cd: 2(2)
2023-06-12 16:34:11.624 T:952 debug <general>: CWinSystemAmlogicGLESContext::CreateNewWindow: cur: iWidth: 1920, iHeight: 1080, iScreenWidth: 3840, iScreenHeight: 2160, fRefreshRate: 60.00, dwFlags: 04
2023-06-12 16:34:11.624 T:952 debug <general>: CWinSystemAmlogicGLESContext::CreateNewWindow: res: iWidth: 1920, iHeight: 1080, iScreenWidth: 3840, iScreenHeight: 2160, fRefreshRate: 50.00, dwFlags: 04
2023-06-12 16:34:11.626 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:26952 dts:643.527 pts:643.927 dur:40.000ms, clock:635.233 level:99
2023-06-12 16:34:11.626 T:952 info <general>: VideoPlayer: OnLostDisplay received
2023-06-12 16:34:11.626 T:952 debug <general>: AMLUtils::aml_handle_display_stereo_mode old mode 3doff new mode 3doff
2023-06-12 16:34:11.626 T:952 debug <general>: AMLUtils::aml_handle_display_stereo_mode - no change needed
2023-06-12 16:34:11.627 T:952 debug <general>: AMLUtils::aml_get_drmDevice - drm devices found: 1
2023-06-12 16:34:11.627 T:952 debug <general>: AMLUtils::aml_get_drmDevice_connector - devices have 2 connector(s)
2023-06-12 16:34:11.628 T:952 debug <general>: AMLUtils::aml_get_drmDevice_encoder - connector[70] is connected with 1 encoder(s)
2023-06-12 16:34:11.628 T:952 debug <general>: AMLUtils::aml_get_drmDevice_crtc - check 1 crtc(s)
2023-06-12 16:34:11.628 T:952 debug <general>: AMLUtils::aml_get_drmDevice_mode - current mode: 2160p60hz
2023-06-12 16:34:11.632 T:952 debug <general>: AMLUtils::aml_get_drmDevice - drm devices found: 1
2023-06-12 16:34:11.632 T:952 debug <general>: AMLUtils::aml_get_drmDevice_connector - devices have 2 connector(s)
2023-06-12 16:34:11.633 T:952 debug <general>: AMLUtils::aml_get_drmDevice_encoder - connector[70] is connected with 1 encoder(s)
2023-06-12 16:34:11.633 T:952 debug <general>: AMLUtils::aml_get_drmDevice_crtc - check 1 crtc(s)
2023-06-12 16:34:11.633 T:952 debug <general>: AMLUtils::aml_get_drmDevice_mode - current mode: 2160p60hz
2023-06-12 16:34:11.633 T:952 debug <general>: AMLUtils::aml_get_drmDevice - drm devices found: 1
2023-06-12 16:34:11.633 T:952 debug <general>: AMLUtils::aml_set_drmDevice_mode - current mode: 2160p60hz, new mode: 2160p50hz
2023-06-12 16:34:11.633 T:952 debug <general>: AMLUtils::aml_get_drmDevice_connector - devices have 2 connector(s)
2023-06-12 16:34:11.634 T:952 debug <general>: AMLUtils::aml_get_drmDevice_encoder - connector[70] is connected with 1 encoder(s)
2023-06-12 16:34:11.634 T:952 debug <general>: AMLUtils::aml_get_drmDevice_crtc - check 1 crtc(s)
2023-06-12 16:34:11.634 T:952 debug <general>: AMLUtils::aml_set_drmDevice_mode - found mode in connector mode list: [7]:2160p50hz
2023-06-12 16:34:11.734 T:969 debug <general>: ActiveAE::SyncStream - average error of -678.443201, start adjusting
2023-06-12 16:34:11.734 T:1423 debug <general>: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: true
2023-06-12 16:34:11.779 T:952 debug <general>: AMLUtils::aml_handle_display_stereo_mode old mode 3doff new mode 3doff
2023-06-12 16:34:11.779 T:952 debug <general>: AMLUtils::aml_handle_display_stereo_mode - no change needed
2023-06-12 16:34:11.779 T:952 info <general>: VideoPlayer: OnResetDisplay received
2023-06-12 16:34:11.779 T:1423 debug <general>: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: false
2023-06-12 16:34:11.779 T:1423 info <general>: CVideoPlayerAudio: display reset occurred, checking for passthrough
2023-06-12 16:34:11.780 T:1423 error <general>: ffmpeg[0x18be5590]: [aac_latm] Invalid channel layout
2023-06-12 16:34:11.780 T:1423 debug <general>: CDVDAudioCodecFFmpeg::Open() Unable to open codec
2023-06-12 16:34:11.781 T:952 info <general>: GLES: Maximum texture width: 8192
2023-06-12 16:34:11.794 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:340ms pts:635.567 Clock:635.226 Level:6
2023-06-12 16:34:11.795 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::DEMUXER_PACKET - checking interlace vfmt: null
2023-06-12 16:34:11.795 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: true
2023-06-12 16:34:11.795 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: false
2023-06-12 16:34:11.795 T:952 debug <general>: CAMLCodec::SetVideoRect:display(0,0,3840,2160)
2023-06-12 16:34:11.795 T:952 debug <general>: CAMLCodec::SetVideoRect:gui(0,0,1920,1080)
2023-06-12 16:34:11.795 T:952 debug <general>: CAMLCodec::SetVideoRect:m_dst_rect(0,0,1920,1080)
2023-06-12 16:34:11.795 T:952 debug <general>: CAMLCodec::SetVideoRect:dst_rect(0,0,3840,2160)
2023-06-12 16:34:11.795 T:952 debug <general>: CAMLCodec::SetVideoRect:m_guiStereoMode(0)
2023-06-12 16:34:11.796 T:952 debug <general>: CAMLCodec::SetVideoRect:m_guiStereoView(0)
2023-06-12 16:34:11.796 T:952 debug <general>: ------ Window Deinit (DialogBusy.xml) ------
2023-06-12 16:34:11.797 T:1411 debug <general>: OnAVChange: CApplication::OnAVChange
2023-06-12 16:34:11.798 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:12882 dts:643.567 pts:643.767 dur:40.000ms, clock:635.252 level:98
2023-06-12 16:34:11.800 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:8707 dts:643.607 pts:643.687 dur:40.000ms, clock:635.254 level:98
2023-06-12 16:34:11.800 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:5055 dts:643.647 pts:643.647 dur:40.000ms, clock:635.255 level:99
2023-06-12 16:34:11.803 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:6191 dts:643.687 pts:643.727 dur:40.000ms, clock:635.257 level:99
2023-06-12 16:34:11.807 T:1424 debug <general>: CVideoPlayerVideo - CDVDMsg::DEMUXER_PACKET - checking interlace vfmt: null
2023-06-12 16:34:11.813 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:10989 dts:643.727 pts:643.847 dur:40.000ms, clock:635.268 level:99
2023-06-12 16:34:11.832 T:1001 warning <general>: CreateLoader - unsupported protocol(pvrchannel_tv@http) in pvrchannel_tv@http://192.168.7.11:9981/imagecache/89
2023-06-12 16:34:11.833 T:1001 debug <general>: Skin Helper Service --> Show OSD Infopanel - number of seconds: 4
2023-06-12 16:34:11.834 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:6334 dts:643.767 pts:643.807 dur:40.000ms, clock:635.288 level:99
2023-06-12 16:34:11.836 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:6738 dts:643.807 pts:643.887 dur:40.000ms, clock:635.291 level:99
2023-06-12 16:34:11.854 T:1003 debug <general>: script.skin.helper.widgets --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {"item":{"title":"The Last Stand","type":"movie"},"player":{"playerid":-1,"speed":1}}
2023-06-12 16:34:11.866 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:285ms pts:635.607 Clock:635.321 Level:5
2023-06-12 16:34:11.868 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:324ms pts:635.647 Clock:635.322 Level:6
2023-06-12 16:34:11.886 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:346ms pts:635.687 Clock:635.341 Level:6
2023-06-12 16:34:11.935 T:969 debug <general>: ActiveAE::SyncStream - average error -0.013769 below threshold of 30.000000
2023-06-12 16:34:11.938 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:384ms pts:635.727 Clock:635.342 Level:6
2023-06-12 16:34:11.938 T:1001 debug <general>: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {"item":{"title":"The Last Stand","type":"movie"},"player":{"playerid":-1,"speed":1}}
2023-06-12 16:34:11.940 T:1001 info <general>: Skipped 2 duplicate messages..
2023-06-12 16:34:11.940 T:1001 debug <general>: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVStart - data: {"item":{"title":"The Last Stand","type":"movie"},"player":{"playerid":-1,"speed":1}}
2023-06-12 16:34:11.941 T:1001 debug <general>: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnAVChange - data: {"item":{"title":"The Last Stand","type":"movie"},"player":{"playerid":-1,"speed":1}}
2023-06-12 16:34:11.978 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:366ms pts:635.767 Clock:635.401 Level:6
2023-06-12 16:34:11.979 T:952 debug <general>: ------ Window Init (DialogSeekBar.xml) ------
2023-06-12 16:34:11.981 T:952 info <general>: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
2023-06-12 16:34:12.030 T:952 debug <general>: [Warning] CGUITextureManager::GetTexturePath: could not find texture 'flags/flags_classic/audiocodec/aac_latm.png'
2023-06-12 16:34:12.034 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:372ms pts:635.807 Clock:635.434 Level:6
2023-06-12 16:34:12.039 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:43756 dts:643.847 pts:644.247 dur:40.000ms, clock:635.494 level:99
2023-06-12 16:34:12.044 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:356ms pts:635.847 Clock:635.490 Level:6
2023-06-12 16:34:12.098 T:1424 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:386ms pts:635.887 Clock:635.500 Level:6
2023-06-12 16:34:12.100 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:23045 dts:643.887 pts:644.087 dur:40.000ms, clock:635.555 level:98
2023-06-12 16:34:12.100 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:14159 dts:643.927 pts:644.007 dur:40.000ms, clock:635.555 level:99
2023-06-12 16:34:12.103 T:1422 debug <general>: CVideoPlayer::ProcessVideoData size:8318 dts:643.967 pts:643.967 dur:40.000ms, clock:635.557 level:99
