Someone made addon to autoskip after pause.
Do you have any link guys?
Oh, ok! Thanks for your suggestion.
Hi!
How do you guys manage your local media?
I have about 200 movies in mkv format, using Arctic: Zephyr - Reloaded skin,
Browse movies in movie set is easy, but for invidual movies, its a pain.
It’s called unpause jumpback addon.
Thank you!
Hi I need help I need the vfd conf for homantics dune premium 4k pro and where I need to put file also the remote.conf
Just received mine yesterday. Has anybody ran into issues running it off a usb drive? I’m considering getting myself a usb nvme reader and a cheap nvme off ebay to run it. I’m using a samsung 3.2 thumb drive right now, and it works great but it definitely gets to a point where it thermal throttles during library scans. Does kind of suck having the USB ports on the side, but oh well. Curious to see what everybody else is running for storage.
You can try this: @white_dragonn
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/278?u=rome1931
I guess usb hub would be the option. or you can try what I am using. bought quite cheap sandisk usb stick that is fast enough for both read and write access and has an aluminium housing. this in fact works like passive heatsink. I don’t have any huge libraries, so no guarantee it will also work in your case.
in case you would like to remap some keys on your BT remote controller, you can do it in gen.xml
there’s a plugin for that (I assume in the original CE repo), but not all keys will work, so better do it manually yourself.
path: /storage/.kodi/userdata/keymaps/gen.xml
you can use this syntax for debug mode (mapped to long pressed 1 key). I recommend to put it in the <global>
section.
<one mod="longpress">Skin.ToggleDebug</one>
Hi, I am looking into buying a Nokia 8010 streaming box
According to the Nokia website Specs, this box comes with ;
Amlogic S905X4-K, CPU: Quad-Core Cortex-A55 20800 DMIPS, GPU: ARM Mali-G31 MP2 850 MHz, SDRAM: 4 GB LPDDR4 RAM , Flash: 32 GB eMMC Flash
There is a link there to buy this item from Amazon (France or Germany), but the specs on the amazon website is different
Chipset: Amlogic S905X3, CPU: Quad-Core Cortex-A55, GPU: ARM Mali-G31 MP2, SDRAM: DDR3: 2 GB , Flash: eMMC: 8 GB
So I was wondering if there are two versions of this box, or amazon not used the correct specs on their page? Any help will be appreciated
Don´t trust Amazon
Don’t trust them as in they have not used correct specs or they are selling older version and the title is wrong?
Be sure to distinguish between Nokia 8010 and 8000
I think I may have found that listing on amazon .de. So 3 options available 8000, 8010 and 800 and yes the description part for the 8010 is actually for the 8000 but the product details, picture and the Title of the android box are correct for the 8010.
Another listing error is the manual (PDF) on the 8010, click it and you’ll get the Streaming Stick 800 manual.
Is there any stable version of CE for dune homatics ?
Thanks a lot
Any of ce nexus 20.0 in released in October is stable.
Attempting to pair a B21 Homatics remote to a Dune HD Homatics Box R 4K Plus box because I wanted the smaller size. The remote pairs and connects. Running btmon I can see it sending the same data values for a given key as the stock Dune B25 remote. Yet Kodi doesn’t respond at all to the keypresses of the B21 remote. Anyone try this and have success, or maybe know if there’s something in Kodi I am missing? I also tried disconnecting my B25 remote so only the B21 was connected, but no joy on that either.
Press 2 pairing buttons on remote to pair again and should start working.
