Hi. Happy New Year.
I send you data to see if it is possible to operate the display.
Bqeel Y8 Max 4 GB S905x3, Gigabit, sm1_s905x3_4g_1gbit.dtb
@TheCoolest Everything is working properly. Thank you. Very attentive as always
There is X96 Max_Plus 2 (S905X3), sm 1_s905x3_4g_1gbit.dtb, x96-x-1gbit-vfd.conf, does not work all the functions of the icons display. What you can advise.
Play, Stop, Pause, Play-Pause… etc.
Install the OpenVFD addon.
Installed, does not work correctly, or I do not know how to use…
Are you using the latest nightly build?
What isn’t working correctly?
Yes, CoreELEC-Amlogic.arm-9.2-nightly_20200103.tar
Yes, work correctly.
I don’t understand, does it work or not?
Work but not all of the characters on the display. (Play, Pause, Start, Stop, Start-stop…etc.
Start\Stop? What icons do you have on the screen?
In Android, such functions are available…
You didn’t tell me which icons the box has.
I used this instruction
@filkint it would be better if you take a picture because what you are not making any sense to any of us here.
I have a X96 Air 2G/16G, one of the earlier versions with 100mbit ethernet. I have read all the posts here, using the provided dtb and vfd file, but my openvfd service keeps failing:
Any idea? Hope it’s not the one, that will never work…
Many thanks
Mike
Post a dmesg | paste output
dmesg output: http://ix.io/26Fs
