How to configure VFD
I volunteered to configure a strange S905W2 TV Box called Leotec Show 2 432 of a friend. The original firmware sucked so much that it didn’t even allow me to insert the WiFi password.
Tried a custom rom (slimBOXtv for Vontar X2) but WiFi and VFD wasn’t working. Moreover, USB Burning Tool no longer detects the box, so now I can’t try different roms.
Fortunately I could install CoreELEC-NE and is working fine, the only thing missing is the VFD.
The VFD has the FD6551 chip. How can I find or make the correct vfd.conf for this strange box? I don’t have access to its original firmware anymore.
Can I adapt the vfd.conf of another box that also has the FD6551 VFD chip?
Thanks!
If you can’t install the original firmware, I don’t think it’s going to be easy.
I need to know what are the original pins used by the display, it’s only available in the original firmware.
If you manage to find the DTB file from the original firmware (where VFD worked) it is often enough.
Thanks for the fast reply!
I already contacted the customer support and asked them for the stock firmware, then I’m going to try to flash the u-boot.bin with BootcardMaker, maybe this will make the box detectable again by USB Burning Tool.
Customer support sent me the original firmware.
I unpacked the firmware and then the _aml_dtb.PARTITION:
It has 3 files:
s4-s905w2-2g.dts (85.6 KB)
s4-s905w2-4g.dts (85.6 KB)
s4-s905w2-1g.dts (85.6 KB)
Is this enough to get the VFD working with your help?
Thanks!
Edit:
	fd655_dev {
		compatible = "amlogic, fd655_dev";
		dev_name = "fd655_dev";
		status = "okay";
		clk_pin = <0x1d 0x2d 0x1>;
		dat_pin = <0x1d 0x2c 0x1>;
Is this what we need?
Yes, that’s a good find.
Looks like this config should work for you:
ltc-box42-vfd.conf (1.2 KB)
Thanks it’s working!
Do you know if VFD is difficult to configure in Android?
In the internal memory I have the slimBOXtv firmware (for Transpeed AV1), the WiFi is working, but as expected the remote and VFD don’t work.
I know what files I need to change for the remote to work, but have no idea about the VFD.
I’m not sure about Android. The Android image must have the VFD driver built-in, and the DTB needs to have the correct configuration for it.
So was looking around and saw a post where someone asked for help with a vdf file for there TX 3 mini.
They was told to boot to Android and run
cat /sys/kernel/debug/gpio
I have ran this and and this is what it says
If some can help that would be great and thank you for all the great work you guys n gels do.
I have just extract the dtb file files from the android that’s running on it with everything working if these help
Also can I use the dtb file I extract as is on CoreElec?
dtb.img (256 KB)
How to extract VFD driver from android and use it in CoreELEC ? Noob here haha
Why would you want to do that?
@Shrek
Try this one in CE and let me know if it works correctly or not.
tanix-tx3-mini-vfd.conf (1.3 KB)
because I have tried many VFD.conf for my X96 X4 box, not all symbols in the VFD works correcly.
I can say that because when I use OpenVFD app, in the setting there is toggle to turn ON/OFF some symbols and it does not work as intended. This is not a deal breaker for me but just curious where the VFD driver located inside android so I can try extract it and import to coreelec system.
You can’t extract it, in most cases it’s built right into the kernel.
Goodnight!!! I’m from Brazil and I have a T95 Max Plus where I use the latest version of EmuELEC 4.6 Stable. Before, I was in EmuELEC 4.6 Test and the vfd.conf file of this TV Box worked perfectly in this test version. It was enough for me to update to EmuELEC 4.6 Stable that the vfd.conf file stopped working. On my Box panel the only information that appears are: CE4. Could you help me to reactivate the LED panel of my T95 Max Plus in EmuELEC 4.6 Stable? Thanks in advance for the help.
This isn’t the place to get support for EmuELEC, they have their own forum.
OK! I have a test version of EmuELEC that uses CoreELEC as a base. I immediately thought it would be the same system. I’ll look for the EmuELEC Forum. Thank you for your attention.
