Interesting DV
FEL? What is it?
Maybe if you keep the pressure on vendors they can pressure up and something good will come out of all the pressure. There’s only so much CE team can do.
And don’t forget that only two devices are capable of CE and pottencially DV at same time. One of those devices is from a vendor that doesn’t even support CoreELEC. So, with all due respect, you’re barking at the wrong tree.
MEL Minimum enhancement layer
FEL Full enhancement layer
The latter is problematic at the moment
Someone In the makemkv forum got a answer from ugoos. 32 bit SDK Only
Good to know, thanks.
I tried the Android OS from the Ugoos AM6 and have weird pixelated artefacts and stutters with DV files and Kodi. :frowning:
I haven’t tried the 0.4.0 RC firmware yet.
Yes there have been answers, but the pressure must be maintained, that’s what I meant. The true target is above, at Amlogic. And Ugoos isn’t a supporter of CoreELEC so any effort will be obviously directed primarily to Minix .
I own both the Minix and the Ugoos with their respective firmwares and both play DV in Kodi/DV and Plex. Both boxes have got some problems but I prefer Minix.
I just updated my Ugoos AM6 Plus with the 0.4.0 RC firmware.
I had a lot of problems with resolution and loading times with the Kodi version of the Play Store.
So I installed the latest version available here :
https://mirrors.kodi.tv/nightlies/android/arm/master/
And damn, everything works perfectly on Android!
Now I have to mourn CoreELEC (for now).
Had some really weird behaviors and crashes. :frowning:
Does that work with mkv Dolby vision rips?
No, I tested it.
Dv Kodi build for android here
https://forum.kodi.tv/showthread.php?tid=360018
Niche Ugoos AM6+ user checking in. Where to send the BTC? :wink:
At the moment I am only accepting whole BTC no fractional values :wink:
What is BTC?
Bitcoin: Bitcoin Exchange | Cryptocurrency Exchange | Binance
You take ether ray?
This is all a joke. I don’t take anything.
:rofl::rofl: all good
Is this reply an April’s fools joke?
Yes @Vasco.
