Interesting DV
dolby vision is over rated,ive never a movie yet with it thats impressed me,hdr to me looks better,netflix dby vision movies look shit
If you watch it on an OLED TV, that’s not true…
Yep, I can only imagine how bad some content looks on inferior televisions.
I’m watching it on my oled b8,ive never seen a dv movie that I prefer over hdr,alot of them look over blown and lose alot of shadow detail and I’m talking about 100gb rips not netflix crap
I have a LG OLED 65B8 and I see the opposite…
On a Panasonic GZ Oled, Dynamic HDR looks better than HDR10.
You mind sharing that kernel module?
This file is not meant to be distributed, if you really want it, you can download the latest image from minix for the U22-XJ and extract it yourself.
Ok will try thanks
I have some rips from the Foundation tv series which is dolby vision, however the Coreelec shows it with wrong colours (mangeta/ green) tint.
I’ve tried all kind of options in coreelec settings regarding color space conversion, however with no luck.
Here’s the media info of that file:
General
Unique ID                                : 201241163418277279064265703557566175510 (0x9765A365784E8B5C34B93C3C92AA1916)
Complete name                            : X:\movie\TvSeries\Foundation.S01E04.Barbarians.at.the.Gate.2160p.ATVP.WEB-DL.DDP5.1.DV.HEVC-CasStudio.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 8.07 GiB
Duration                                 : 45 min 47 s
Overall bit rate                         : 25.2 Mb/s
Writing application                      : mkvmerge v61.0.0 ('So') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 24.4 Mb/s
Width                                    : 3 840 pixels
Height                                   : 1 920 pixels
Display aspect ratio                     : 2.000
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.138
Stream size                              : 7.82 GiB (97%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Bit rate mode                            : Constant
Bit rate                                 : 768 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 252 MiB (3%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Complexity index                         : 16
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 6 min 15 s
Bit rate                                 : 7 b/s
Count of elements                        : 11
Stream size                              : 370 Bytes (0%)
Title                                    : English (Forced)
Language                                 : English
Default                                  : Yes
Forced                                   : Yes
Text #2
Format                                   : UTF-8
Duration                                 : 44 min 18 s
Bit rate                                 : 75 b/s
Count of elements                        : 613
Stream size                              : 24.5 KiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #3
Format                                   : UTF-8
Duration                                 : 44 min 22 s
Bit rate                                 : 78 b/s
Count of elements                        : 651
Stream size                              : 25.7 KiB (0%)
Title                                    : English (SDH)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #4
Format                                   : UTF-8
Duration                                 : 45 min 43 s
Bit rate                                 : 104 b/s
Stream size                              : 35.0 KiB (0%)
Language                                 : Arabic
Default                                  : No
Forced                                   : No
Text #5
Format                                   : UTF-8
Bit rate                                 : 111 b/s
Count of elements                        : 576
Stream size                              : 37.2 KiB (0%)
Language                                 : Bulgarian
Default                                  : No
Forced                                   : No
Text #6
Format                                   : UTF-8
Bit rate                                 : 66 b/s
Count of elements                        : 616
Stream size                              : 22.1 KiB (0%)
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #7
Format                                   : UTF-8
Bit rate                                 : 64 b/s
Count of elements                        : 615
Stream size                              : 21.7 KiB (0%)
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #8
Format                                   : UTF-8
Bit rate                                 : 66 b/s
Stream size                              : 22.2 KiB (0%)
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #9
Format                                   : UTF-8
Bit rate                                 : 68 b/s
Count of elements                        : 581
Stream size                              : 23.0 KiB (0%)
Language                                 : Czech
Default                                  : No
Forced                                   : No
Text #10
Format                                   : UTF-8
Bit rate                                 : 73 b/s
Count of elements                        : 579
Language                                 : Danish
Default                                  : No
Forced                                   : No
Text #11
Format                                   : UTF-8
Bit rate                                 : 66 b/s
Count of elements                        : 531
Language                                 : Dutch
Default                                  : No
Forced                                   : No
Text #12
Format                                   : UTF-8
Bit rate                                 : 65 b/s
Count of elements                        : 569
Stream size                              : 22.0 KiB (0%)
Language                                 : Estonian
Default                                  : No
Forced                                   : No
Text #13
Format                                   : UTF-8
Bit rate                                 : 70 b/s
Count of elements                        : 614
Stream size                              : 23.6 KiB (0%)
Language                                 : Finnish
Default                                  : No
Forced                                   : No
Text #14
Format                                   : UTF-8
Duration                                 : 45 min 12 s
Bit rate                                 : 69 b/s
Count of elements                        : 723
Stream size                              : 23.1 KiB (0%)
Title                                    : French (Canada)
Language                                 : French
Default                                  : No
Forced                                   : No
Text #15
Format                                   : UTF-8
Bit rate                                 : 69 b/s
Count of elements                        : 722
Title                                    : French (France)
Language                                 : French
Default                                  : No
Forced                                   : No
Text #16
Format                                   : UTF-8
Bit rate                                 : 74 b/s
Count of elements                        : 561
Stream size                              : 24.9 KiB (0%)
Language                                 : German
Default                                  : No
Forced                                   : No
Text #17
Format                                   : UTF-8
Bit rate                                 : 124 b/s
Count of elements                        : 609
Stream size                              : 41.7 KiB (0%)
Language                                 : Greek
Default                                  : No
Forced                                   : No
Text #18
Format                                   : UTF-8
Bit rate                                 : 97 b/s
Stream size                              : 32.7 KiB (0%)
Language                                 : Hebrew
Default                                  : No
Forced                                   : No
Text #19
Format                                   : UTF-8
Bit rate                                 : 198 b/s
Stream size                              : 66.6 KiB (0%)
Language                                 : Hindi
Default                                  : No
Forced                                   : No
Text #20
Format                                   : UTF-8
Bit rate                                 : 69 b/s
Language                                 : Hungarian
Default                                  : No
Forced                                   : No
Text #21
Format                                   : UTF-8
Bit rate                                 : 78 b/s
Stream size                              : 26.2 KiB (0%)
Language                                 : Indonesian
Default                                  : No
Forced                                   : No
Text #22
Format                                   : UTF-8
Duration                                 : 45 min 45 s
Bit rate                                 : 76 b/s
Language                                 : Italian
Default                                  : No
Forced                                   : No
Text #23
Format                                   : UTF-8
Bit rate                                 : 61 b/s
Count of elements                        : 636
Stream size                              : 20.5 KiB (0%)
Language                                 : Japanese
Default                                  : No
Forced                                   : No
Text #24
Format                                   : UTF-8
Bit rate                                 : 77 b/s
Stream size                              : 26.1 KiB (0%)
Language                                 : Korean
Default                                  : No
Forced                                   : No
Text #25
Format                                   : UTF-8
Bit rate                                 : 72 b/s
Count of elements                        : 601
Stream size                              : 24.2 KiB (0%)
Language                                 : Latvian
Default                                  : No
Forced                                   : No
Text #26
Format                                   : UTF-8
Bit rate                                 : 73 b/s
Stream size                              : 24.8 KiB (0%)
Language                                 : Lithuanian
Default                                  : No
Forced                                   : No
Text #27
Format                                   : UTF-8
Bit rate                                 : 69 b/s
Stream size                              : 23.3 KiB (0%)
Language                                 : Malay
Default                                  : No
Forced                                   : No
Text #28
Format                                   : UTF-8
Bit rate                                 : 69 b/s
Language                                 : Norwegian
Default                                  : No
Forced                                   : No
Text #29
Format                                   : UTF-8
Bit rate                                 : 68 b/s
Count of elements                        : 604
Language                                 : Polish
Default                                  : No
Forced                                   : No
Text #30
Format                                   : UTF-8
Bit rate                                 : 72 b/s
Stream size                              : 24.4 KiB (0%)
Language                                 : Portuguese
Default                                  : No
Forced                                   : No
Text #31
Format                                   : UTF-8
Bit rate                                 : 67 b/s
Count of elements                        : 597
Stream size                              : 22.7 KiB (0%)
Title                                    : Portuguese (Brazil)
Default                                  : No
Forced                                   : No
Text #32
Format                                   : UTF-8
Duration                                 : 44 min 47 s
Bit rate                                 : 112 b/s
Count of elements                        : 575
Stream size                              : 36.9 KiB (0%)
Language                                 : Russian
Default                                  : No
Forced                                   : No
Text #33
Format                                   : UTF-8
Bit rate                                 : 67 b/s
Stream size                              : 22.6 KiB (0%)
Language                                 : Slovak
Default                                  : No
Forced                                   : No
Text #34
Format                                   : UTF-8
Bit rate                                 : 61 b/s
Count of elements                        : 557
Stream size                              : 20.7 KiB (0%)
Language                                 : Slovenian
Default                                  : No
Forced                                   : No
Text #35
Format                                   : UTF-8
Bit rate                                 : 73 b/s
Count of elements                        : 623
Title                                    : Spanish (Latin America)
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Text #36
Format                                   : UTF-8
Bit rate                                 : 73 b/s
Count of elements                        : 606
Stream size                              : 24.6 KiB (0%)
Title                                    : Spanish (Spain)
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Text #37
Format                                   : UTF-8
Bit rate                                 : 71 b/s
Stream size                              : 24.1 KiB (0%)
Language                                 : Swedish
Default                                  : No
Forced                                   : No
Text #38
Format                                   : UTF-8
Bit rate                                 : 225 b/s
Stream size                              : 75.6 KiB (0%)
Language                                 : Tamil
Default                                  : No
Forced                                   : No
Text #39
Format                                   : UTF-8
Bit rate                                 : 202 b/s
Stream size                              : 67.7 KiB (0%)
Language                                 : Telugu
Default                                  : No
Forced                                   : No
Text #40
Format                                   : UTF-8
Bit rate                                 : 191 b/s
Stream size                              : 64.0 KiB (0%)
Language                                 : Thai
Default                                  : No
Forced                                   : No
Text #41
Format                                   : UTF-8
Bit rate                                 : 75 b/s
Stream size                              : 25.1 KiB (0%)
Language                                 : Turkish
Default                                  : No
Forced                                   : No
Text #42
Format                                   : UTF-8
Bit rate                                 : 112 b/s
Stream size                              : 37.7 KiB (0%)
Language                                 : Ukrainian
Default                                  : No
Forced                                   : No
Text #43
Format                                   : UTF-8
Bit rate                                 : 98 b/s
Stream size                              : 33.1 KiB (0%)
Language                                 : Vietnamese
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : :Chapter 01
00:00:36.911                             : :Chapter 02
CoreELEC doesn’t support DV right now, at all.
It also depends on your device, most of them don’t support DV either.
Your file is pure DV, it doesn’t have any fallback layers such as HDR10, therefore it’s played in wrong colors.
You can try to play it directly from your TV’s player.
Good Morning,
Is there away to enable Dolby Vision on CoreELEC on Minix U22. …As Currently I’m in a huge dilemma… I like CoreELEC as its light weight and Dolby Atmos and DTS X Passthrough Work without any issues, as these don’t work on Android but on the other Hand Dolby Vision doesn’t Work and i’m stuck with HDR 10 @ 10BIT… whilst if i use kodi on the Minix Android OS Dolby vision works and there a difference in the picture quality.
Thanks,
Et
No, there is no way
Thanks for your reply. I assumed that is the reply unfortunately… It seems that this isn’t something which is going to happen any time soon.
You can search the forum.
It was explained many times.
i got this answer 2 years ago :slight_smile:
And unfortunately you may get it two years from now.
(Just add a rule to ignore files with ā€˜DV.’ in their name in your downloading (if that is what you’re doing) - and move on with your life…with any luck HDR10+ will become dominant and another stupid proprietary format will kick the bucket…)
The only solution when someone build a 32-bit CoreELEC.
Most hardware doesn’t support DV regardless if the software does
@bossanova808 that will never happen. It’ll be the other way around. DV is the dominant dynamic HDR As opposed to HDR10+, as Netflix have them onboard. Scale wins, but whatever.
