Ok, thanks!
I looked at the debug log, but couldn’t make much of it…
I could upload an image, but since those are in the range of 40-50 GiB, I’m not sure how to do that effectively
What I’m going to do first is, that I will try a frash installation and see if that changes anything. I will report back after that.
EDIT
OK, I made a fresh install and an interesting observation with that: the first time I started one of the problematic ISOs, some of them at least started playing the trailers etc. I could even start Ratatoulie with a functional menu. But then I couldn’t start the disks a second time!
So now the ISOs behave the same way as on my old system. So at least there is no benefit of having a fresh install.
Is it OK if I upload a log of one or two of there problematic disks?
let me ask i put the file in update and deleted the old jre but when i reboot it still wont update your version. Do I need to unzip it and what else do I need to do to run that version. thanks
Hi, first of all, thanks for this image @vpeter, it is really useful and I can now read BDMV folders like original discs.
The only drawback I had is that the official version updated with the same version and overwrote your image and I had to re-update it to get the BD menus working again. If you keep creating images for future updates, is there a way to activate your updates instead of the official ones? At the moment, I have changed to manual updates instead of automantic to prevent this from happening again.
Thanks.
