Save file somewhere and use
mount -o bind libbluray.so.2.1.2_aml /usr/lib/libbluray.so.2.0.2
systemctl restart kodi
Thank you!
Unfortunately nothing changed. I mean the bug is still there.
Which is weird, because the UHD BD playlist is almost the same as the normal BD playlist.
Maybe it is just check the version and not even try to get the language infoā¦
Where can I find the source for this 2.1.2?
OK, I had this already.
So if you can update libbluray and compile it.
Canāt you share or just update it on CoreElec build?
This would improve compatibility.
You would also need to update libxml2 for it to work.
Hi everyone
I was a bit away but happy to see things seem to go in the right direction even if it is now holydays for many people.
thank you vpeter,Pelica,Fandangos,ant123ā¦
Dear all.
Iāve seen this commit in the last CoreElec nightly build:
I cannot test now, anyone knows if it support Amlogic S9XX devices?
Thanks.
Still software decoded video with latest CoreELEC and smurfs BD
Sadly I donāt see how video is actually played and why sw decoding is used.
On my Odroid N2, I can not read the menu of my ripped blurays. Is there a manipulation or configuration to implement?
Check Kodi debug log for any clues. It should just show menu without any extra configuration.
I saw the jre.zulu somewhere on the CE repo and thought to try it.
It prompts to either pick a playlist or Show Menu. However choosing menu led to only hearing the audio but no video. Only tried one image so far.
Is it supposed to work?
It works but not for all disks.
All the Criterion Collection discs Iāve tried donāt display a menu.
@vpeter I have been following your posts in this topic and installed the jre.zulu addon. I tried to run an bluray iso but I end up with errors in the kodi.log and no menu is not showing up.
The error is āFailed to load libbluray.jarā and I run coreelec nightlies on an Odroid N2
Any advice would be helpful
paradix, after you install this addon you need to restart Kodi or reboot the device. After that it will work. If not post kodi log.
I just made fresh install of the addon and it is still working.
Hmm, ok Iāll try later. But Iām pretty sure I did restart kodi
We will see.
For the time being here is the log from yesterday
@vpeter need to edit post, as I have only 3 replies as new user ![]()
Iām running coreelec nightly - CoreELEC (official): nightly_20200410 (Amlogic-ng.arm)
But I have updated the library based on the posts previous to
Iām not sure which image you are running because of
DEBUG: CBlurayCallback::Logger - bluray.c:1413: libbluray version 1.1.2
We are still on 1.0.2 (this is what I get in kodi log)
DEBUG: CBlurayCallback::Logger - bluray.c:1408: libbluray version 1.0.2
As a workaround you could copy file libbluray-j2se-1.1.2.jar and libbluray-awt-j2se-1.1.2.jar to folder /storage/.kodi/addons/tools.jre.zulu/
wget -O /storage/.kodi/addons/tools.jre.zulu/libbluray-j2se-1.1.2.jar http://vpeter.libreelec.tv/BD-J/libbluray-j2se-1.1.2.jar
wget -O /storage/.kodi/addons/tools.jre.zulu/libbluray-awt-j2se-1.1.2.jar http://vpeter.libreelec.tv/BD-J/libbluray-awt-j2se-1.1.2.jar
But please tell me which image you are using?
Ok. So I updated to 9.2.2
CoreELEC (official): 9.2.2 (Amlogic-ng.arm)
And now canāt even play the bluray iso at all
@vpeter switched to CoreELEC (official): nightly_20200415 (Amlogic-ng.arm) and still getting the same results as in the pasted log.
I did copy that jars manually but the libbluray is still 1.0.2, so why would it need 1.1.2 jars?
