In your first log I saw you used 1.1.2. No idea how and why.
There is no need to any manual setup just this addon install and menus should work. But menus are not working on all movies. Some work, some don’t.
I don’t know if nfs could cause anything but for a test I would copy this movie to local storage and try to play it. Also try to remove this addon if you suspect it has anything to do with not playing. Just in case.
As I wrote above I tested this few hours back and samples I have are working.
Well the newer versions of libbluray supports UHD as well as having alot of bugfixes regarding the menu on ordinary BDs… When it comes to what CE Kodi understands and what not, I have no idea… I’m not that tech savvy
Tested this, unfortunately no improvement. Still getting “The menu on this blu-ray is not supported” on certain disks.
Edit: Wait a moment, did not install jre tools, only created a directory…
Confirmed, it works!
Tested over 10 blu-rays, previously saying “The menu on this blu-ray is not supported”.
Now they all work.
Still having 3 blu-rays that are causing box to reboot but that is another story.
I can also confirm I’m using nightly_20200423 and the two new libbluray 1.2.0 files and after trying 3 blurays iso’s with menus that didn’t work before they now do
This is playing Star Trek (2016) Blu-Ray folder structure that previously gave the “The menu on this blu-ray is not supported” message, now the menu works fine.
