I may have spoken too soon - looks like there’s an aggressive memory leak, I can only guess it’s one of the Amlogic drivers since it’s in kernel space.
I’ll try to get some slab debug info if I can work out how to modify kernel params on CE, but looks like something is constantly calling kmalloc and never freeing the memory.
Oh, I installed from Oowow a couple days ago and thought that would be the latest nightly. Update notification came through when I powered up today and memory is now looking nice and flat, kmods for docker are in too, thanks muchly
UHD content does appear to flicker and hitch every few seconds after updating to the latest build, is this a known issue? Can provide logs if that would be useful.
ETA: The hitching wasn’t present on the previous build.
This is likely related to the currently dodgy audio driver (and would be less an issue once pass-through works), but just in case there’s anything I can try - when connected to my receiver (Denon AVR-X1700H) only 2ch LPCM works. When Kodi tries to send > 2ch LPCM to the receiver, the AVR displays unknown format and no audio is received.
If I connect the VIM4 to my TV (Sony XR-77A80J) and have the LPCM sent through the TV to the receiver via eARC, I can get > 2ch audio, but A/V sync is much more reliable the other way around. The receiever plays LPCM from other sources fine (I have an older x86 Kodi box with regular HDA audio that works no problem).
The upload with full logs option appears to be broken on 20221117 (consistently fails and says to retry), but I can upload the Kodi logs separately if required - there doesn’t seem to be anything super-interesting in them though, Kodi is sending the right channel counts/bit-depths/etc to the audio codec for output. Below are the configs/debug-info when connected to each of the two devices. Other than failing to detect DV compatibility when connected to the TV (and missing HDR10+ on the receiver), I don’t see much in the way of significantly different between the two:
Has someone working on “12:01” bug? What I’m talking about: When playing local MP4 video, Kodi freeze on “12:01” time and only seeking forward can resume normal playback. You can check this yourself - no logs needed from other people.
Hm… After the recent updates, there no sign of this “12:01” bug, for now. Just some videos can’t even open successfully (some of them plays without sound), but this can be Kodi related or Amlogic binary blob issues. Clearly, it needs more time.
If you read the thread you’ll see there are issues with the audio driver - particularly, passthrough of HBR audio is broken, workaround is to use LPCM, though that has some issues too…
