Kinhank G1
Brilliant, the text instructions are what I was after really, I’d gleaned the bat file was AFTER the flashing but the transcript alone wasn’t good at saying what boxes to uncheck etc.
I did not find a way to message you but I’m interested by your firmware for this box… Thank you !
Hi Sholander I’m interested to update this box with the hungphutho firmware please can you send me a link to download it ? Thanks All the best
Hello Sholander I’m Interested too to get this hunghphutho firmware for the kinhank G1 … thanks to send me a link to download it !
I had to run the commands in the bat file in power shell manually one by one on Windows 11, somehow it did not work with cmd. Otherwise it is the usual amlogic burning process, same for years now. Important though which software version you use.
@linuxo and @mike59, you have to ask @hungphutho to send you the needed files. It is not my FW, and I don’t have the permission to share it. You have to wait until he will answer to your request.
I always run cmd with admin privileges, and it works OK with this .bat file.
To all:
Private messages are allowed with trust level 2.
This means 10 posts entered, 25 posts read, minimum 60 minutes read time, 15 days visited and 10 reply written.
Hi hungphuto I can not messaging here I dont know why… I posted few read and so on… I’m interested by your firmware for the G1 can you send me the link too please ? Thanks All the best !
Hi hungphutho I can not message you here but very interested by your Fw … Will be Very appreciated if you send me the link to download it ! Thx !:+1: or mail janolin@protonmail.com
@linuxo , @mike59 @janolino
link public dowload fw img 781.46 MB file on MEGA
Thank you so much ! But you said “if I post public link the G1 team will fix the box”… ? Anyway I will order it now because this box seem to be the best for now THANKS !
After you install this firmware, I don’t think that anybody can “fix” your box, except you, so don’t worry abut it.
Is it better to check what firmware is already installed before updating to hungphutho FW ?
Thanks to you !!!
NO! To be on the safe side DO NOT OPEN ANDROID before you flash this firmware!
If you want to check if the box is with original, not blocked, firmware just install CoreElec -ng version. If you get CE working, your box is ready for this firmware.
If you cannot install CE on your new box, either return it, or use only Android on it…
Can we try ce-ng before upgrading to hungphutho FW ?
Of course, in fact you should. If CE does not install/work, then your box is already locked, and you will not be able to install this moded firmware.
Yeahh Thanks so much for that and all help @Sholander @hungphutho. Box ordered today with AE I can’t wait to try that ! Thank you
I installed many times ago the CE NE nightly.
I thought the DV FEL is working but I got receantly a test file and it is not working.
Do you know why?
If I wanted to run CE NG via SD card I got an eearch64 error.
After I copy the ng dovi.co file and pasted it into the config folder I got error:
Android Dolby Vision kernel module is not compatible
No Dolby Vision media playback possible!
Please upgrade Android firmware of your device to minimum Linux kernel version ‘5.4.210’.
Dolby Vision media will be displayed in HDR instead Dolby Vision until the firmware fulfill the minimum requirements.
What can I do to play the DV FEL?
