Kinhank G1
Thanks for this. Can anyone point me to the instructions for moving the data partition to emmc?
A post was merged into an existing topic: Help, support CPM build
You can boot to coreelec using the above instructions.
Thank you to everyone who figured this out!
I restored my V2 that I updated back when the Android update first came out, not realizing it would lock the bootloader.
I was able to do it without soldering and had to try a few times since I had emmc timeout errors but eventually got it working.
Running CoreElec isn’t the problem.
But whichever dtb I try, eth. Capable of speeds of only 100Mbp!
That dovi.ko doesn’t work for my setup :confused:
DTB,s from post 700 also no boot.
Iam using modded DTB kinhank.
So boots with wifi and Bluetooth both working
No ethernet…
The dovi.ko from my Ugoos loads
During Dolby Vision File Test
TV flags as Dolby Vision
Screen is black,i can hear audio
I must be doing something wrong
Or is there issues with latest nightly. ng??
Any suggestions :thinking:
No, except to try installing “CoreELEC-Amlogic-ng.arm-21.1-Omega-Generic.img.gz” (from August 22.) If it does not contain needed kinhank dtb.img use one from post 700. If any of those does not work, you have a different hardware revision that is not known to me…
Can you tell us what the serial number of your box starts with? I have one with a rev-a chip and it starts with 24200xx. @kszaboa has one starting with 24600xx for which the original dtb didn’t work I think.
Also did you try the new revision dtb from post 741?
Same as mine; have no experience with other revisions…
Thanks for the help, now the connection is running above 600.
I also changed the cable and port.
So now it works.
You’re right, mine is 24600xx & is only 100mb & even nfs/smb with high bitrate files struggles where a my minix s922x play it fine.
You have a link to the store on AliExpress?
Yes, there is, but I won’t be able to send it until tomorrow.
Did you try using WiFi ? I’m able to get around 250mbps on iperf with the WiFi 6 router a couple of meters away from the box.
It’s not great but it works ok for high bitrate playback. My iPhone manages to get 500mbps from the same spot.
I get 220mb but nfs/smb is a mystery, i use the same sdcard in the Minix so same settings, i think is rev d of s905x4 is too weak, does anyone use nfs/smb here?
Does anyone have a dtb file for nightly NE with working wifi and bt? (rev d)
Thx
This DTB works on my Kinhank
Ethernet
Wifi
Bluetooth
Dovi .ko does not
I have older board from image i posted
Looks like 2402xxxxx…
V2 2021 04 25 stamped on board.
Maybe version is a factor as compared to serial #
Image from hungphutho shows serial 2406xxx
V3 2021 08 11
So i have working DTB
Still issue with dovi.ko
Dovi file from August
Dovi file from September
Both load
Black Screen
I do get a message that DTB is out of date
Please update
You can try this:
You can get the uart cable cheaper on aliexpress
just add this item when you order the Kinhank G1
get the
: CP2102 Red
​​​​​​​second option for $1.56 (pre tax)
It’s good (cheap) insurance to make sure you can get it to load CoreELEC
Wait for the next discount in probably 2 weeks. also got Chinese new year coming up, might get good sales then too. Should be able to pick this up for under $50 (pre tax)
(if you want to order the uart separately then use this seller
($1.39 pre tax, add 3 choice items for free shipping)
