It worked really good in CE 8.90.5., librespot using the Kodi audio mode. I heard music over librespot, gone to the channel list and select a live TV channel, the live TV started and librespot audio stoped.
It worked also, but not quite so good, before CE 8.90.5 with using two different ALSA devices.
Currently, CE 8.95.0, I have a general problem with switching live TV channels, see
But this is independent from using librespot before.
My problem with channel switching in TVHeadend IS dependent on librespot. If I deactivate librespot, there are no problems with channel switching in TVHeadend.
Yes, this is my problem too. If you have Librespot enabled, you can start a LiveTV channel, but can’t switch channels anymore. It freezes completely and you need to unplug from power. I have the same problem, it is very annoying
I hope it is possible to fix this.
EDIT: tried 8.90.5, same problem. If Librespot is enabled, LiveTV hangs.
Update: awiouy (the developer of Librespot addon) fixed the TVHeadend zapping bug, added perfect support for ALSA (now configuration wizard works). Also there are some improvement to Kodi mode playback (like artist, songs, etc information).
Check out the addon for CoreElec at Libreelec forum: Link
Yes, it is fixed now, that is what I wanted to report back here at CoreElec forum. I don’t know when the new addon will be available in repository, but you can grab the updated 111j version from the link a provided.
I can confirm that Librespot is working as it should on CoreElec (together with TVHeadend, and ALSA wizard is working too).
Everyone having Android equipment and using spotify with librespot addon in kodi should take a look in googles play store. There is an app called HiFy. HiFy enables spotify to see and use Airplay and DLNA devices via spotify connect. This is nice also if you have an AVR Reciever on which spotify connect was deactivated ealier this year.
Did anyone else notice problems with the addon in 8.95.7?
For me suddenly it doesn’t work anymore, shows up in spotify but there’s no playback in kodi after choosing it.
Just tried an older ce version, also not working. Tried wiping userdate and reinstalling it, still not working. Idk what I messed up there. Just remember trying to play back a podcast which didn’t work, that’s it.
Yes, unfortunately Marcel Veldt’s addon causes freezes while playing video files, switching tv channels, …
So, the Librespot addon is a good compromise to it (although no direct access to the Spotify library).
I wonder if a new version of Librespot is pushed to Libreelec repo, when will it be available for CE too? It fixes an annoying bug. It is revision 115.
Hi everyone,
I am currently on CE 9.2.0 on my T95Q. Works great !
I have installed Librespot 23-07-2019 and entered my login and password. On my phone, I can’t see the device in Spotify Connect. Does it still World with 9.2.0?
