Looking for users with no working WiFi or BT
Hello, wireless WiFi is ready, but Bluetooth is not yet supported. May I ask if it can be resolved.
Does wifi works now? Did you test it?
Wireless test normal
Hi
I have a Kinhank G1.
My problem is that wifi and bluetooth sometimes work and sometimes not.
It works after one start and not after another.
It looks like the bluetooth/wifi drivers are not starting every time.
If I get a startup where everything is OK, then the connection is stable until the device is turned off.
CoreELEC (official): 21.0-Omega_nightly_20240427 (Amlogic-ne.aarch64)
      Machine model: Amlogic
     CoreELEC dt-id: sc2_s905x4_kinhank_g1
CoreELEC:~ # dd if=/dev/dtb | gzip > /storage/backup/dtb.img.gz
512+0 records in
512+0 records out
262144 bytes (256.0KB) copied, 0.060411 seconds, 4.1MB/s
CoreELEC:~ # udevadm info /sys/bus/sdio/devices/* | paste
Unknown device "/sys/bus/sdio/devices/*": No such device
https://paste.coreelec.org/TXPiyX
CoreELEC:~ # udevadm info /sys/bus/pci/devices/* | paste
Unknown device "/sys/bus/pci/devices/*": No such device
https://paste.coreelec.org/LwAsjQ
CoreELEC:~ # lspci | paste
https://paste.coreelec.org/FVDPXn
CoreELEC:~ # dmesg | paste
https://paste.coreelec.org/Jay5Sp
Connection name for terminal sharing: meriox
dtb.img.gz (84.5 KB)
No WiFi on N2 with TP-Link AX1800 /TX20U Plus adapter. Realtek 8832AU Wifi 6 chipset. Blank screen under “Connections” in GUI.
I can’t ssh in to look at dmesg output since there’s no network… :slight_smile: but I’ll bring it down here and see if I can see anything when I plug it in.
Is this still being worked on? Let me know if there is anything I can do, tests I can run, etc., to help get this working.
Cheers,
- Phil
Try Amlogic-no.
Portisch, will you help me with my case?
I reinstalled coreelec ne to the stable version, then nightly again.
I also tried different dtb files but nothing helps.
When there is some time…
amlogic-pcie f5000000.pcie: Error: Wait linkup timeout. no idea about this issue
Thanks Portisch. Do you know if that chipset is actually supported in Amlogic-NO?
I did a bit of looking around and this is looking pretty grim, see here:
I would suggest that folks avoid this device like the plague. I’ll be looking for a Mediatek-based device, was trying to avoid Realtek anyway but apparently didn’t do my due diligence well enough.
At least it looks nice, and could serve as a sleek and modern-looking paperweight…
- Phil
I got a Qsmarter Nova with a amlogic S905x 2GB ram 8GB rom and realtek wifi 8189FTV wifi is not working at Omega ng 212 how can i fix this ?
https://paste.coreelec.org/vvpa0G
By reading first post?
gets: Unknown device “/sys/bus/sdio/devices/*”: No such device
I think there is a “slow sdio” option in CE settings, hardware. Enable it, reboot and test again.
wifi still not displayed
Holy crap - looks like there’s a working Linux driver for the 8832au here:
This driver allegedly works for the 8832au as well. I’m willing to try it since I waited too long to be able to return it.
See here:
https://www.reddit.com/r/linuxquestions/comments/12axh0h/rtl8832au_drivers_for_linux_pop_os/
ok i think there is no solution…
Hey how can I insert an wifi driver into a android tv rom (sorry if it is offtopic, it is for my mom, I am setting up a box with other rom but I dont know how to do it so I’m asking it here, sorry again)
We’re short on money and a friend gave us a tx3 mini with an S9082C wifi chip, but the wifi doesn’t work, If someone knows, please help me
Thanks in advance
I’ve already compiled an .ko file but I don’t know where to use it. I compiled this GitHub - CoreELEC/smartchip
Can I pm you?
This forum is for CoreELEC support. For Android you have others.
My N5Max X4 uses the Amlogic W155S1 WiFi and Bluetooth chip, and I am unable to use Bluetooth with the dtb provided in the library. The command line query shows that the device is not loaded. Is there a solution to this problem?
N5MAX X4 WIFI BT W155S1 CPU S905X4 NO BT YES WIFI
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:1
M: sdio:0000:1
R: 1
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:1
E: SUBSYSTEM=sdio
E: DRIVER=aml_w1_sdio
E: OF_NAME=wifi
E: OF_FULLNAME=/sdio@fe088000/wifi@1
E: OF_COMPATIBLE_0=sprd,unisoc-wifi
E: OF_COMPATIBLE_N=1
E: SDIO_CLASS=07
E: SDIO_ID=8888:8888
E: MODALIAS=sdio:c07v8888d8888
E: USEC_INITIALIZED=13652308
E: ID_SDIO_CLASS_FROM_DATABASE=WLAN interface
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:2
M: sdio:0000:2
R: 2
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:2
E: SUBSYSTEM=sdio
E: SDIO_CLASS=07
E: USEC_INITIALIZED=13642138
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:3
M: sdio:0000:3
R: 3
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:3
E: SUBSYSTEM=sdio
E: SDIO_CLASS=07
E: USEC_INITIALIZED=13642147
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:4
M: sdio:0000:4
R: 4
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:4
E: SUBSYSTEM=sdio
E: SDIO_CLASS=07
E: USEC_INITIALIZED=13647896
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:5
M: sdio:0000:5
R: 5
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:5
E: SUBSYSTEM=sdio
E: SDIO_CLASS=07
E: USEC_INITIALIZED=13655407
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:6
M: sdio:0000:6
R: 6
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:6
E: SUBSYSTEM=sdio
E: SDIO_CLASS=07
E: USEC_INITIALIZED=13660860
P: /devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:7
M: sdio:0000:7
R: 7
U: sdio
V: aml_w1_sdio
E: DEVPATH=/devices/platform/fe088000.sdio/mmc_host/sdio/sdio:0000/sdio:0000:7
E: SUBSYSTEM=sdio
E: SDIO_CLASS=07
E: USEC_INITIALIZED=13654961
