Hello, I’m commenting here that I have a realtek 8811au usb wifi, I’m testing it on a s905w2/s905y4 (t95w2), with core 21 (stable and nightly versions)
It does not recognize it, I passed the info in case it were possible to add the drivers. Thank you
Bus 001 Device 003: ID 0bda:c811 Realtek Semiconductor Corp. 802.11ac NIC
G7 MAX
Issue is No internal BT with Coreelec
Cdtech brand wifi module CDW.47W3155-00
CE 21 omega NE stable
udevadm info
https://paste.coreelec.org/FernandoSerious
dmesg | paste
https://paste.coreelec.org/ColsonJinxy
System log
https://paste.coreelec.org/finchleynoise
Hi there,
I bought a Magicsee N5max X4 Androidbox.
When the box arrived, I installed coreelec straight away.
everything actually works, except for bluetooth.
Apparently there is no bluetooth module installed.
I have already experimented with the command: udevadm info /sys/bus/sdio/devices/sdio*.
The result is: Unknown device “/sys/bus/sdio/devices/sdio*”: No such device
Außerdem habe ich noch folgende Befehle ausgeführt:
lspci -nnk | grep -iA2 net; lsusb; hciconfig -a; dmesg | egrep -i ‘blue|firm’
Result:
CoreELEC:~ # lspci -nnk | grep -iA2 net; lsusb; hciconfig -a; dmesg | egrep -i ' blue|firm'
Bus 001 Gerät 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Gerät 001: ID 1d6b:0003 Linux Foundation 3.0 Root-Hub
Bus 002 Gerät 002: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s-Brücke, ASM1053E SATA 6Gb/s-Brücke, ASM1153 SATA 3Gb/s-Brücke, ASM1153E SATA 6Gb/s-Brücke
[ 1.179732@3] hifi4dsp: hifi4dsp0, Firmware :base:0x30000000, size:0x800000, virt:ffffffc013792000
[ 1.181002@2] aml_aucpu aucpu: Direktes Laden der Firmware für aucpu_fw.bin mit Fehler -2 fehlgeschlagen
[ 2.474447@1] plattform regulatory.0: Direktes Laden der Firmware für regulatory.db mit Fehler -2 fehlgeschlagen
[ 4.979621@1] kernel-overlays-setup: Firmware aus /usr/lib/kernel-ove rlays/base/lib/firmware hinzugefügt
[ 9.233962@3] aml wifi module SN:0631 sn txt nicht gefunden, die rf config: /usr /lib/firmware/w1/aml_wifi_rf.txt
[ 10.782773@0] Bluetooth: bt_init: Core ver 2.22
[ 15.349933@0] Registrierter Firmware-Treiber erfolgreich.
[ 15.352266@0] firmware_codec firmware_vdec: Direktes Laden der Firmware für video/h 264_enc.bin mit Fehler -2 fehlgeschlagen
[ 15.356227@0] loa
CoreELEC:~ # udevadm info
A device name or path is required
CoreELEC:~ # dmesg | paste https://paste.coreelec.org/CouplesBrother
CoreELEC:~ # System log
-sh: System: command not found
CoreELEC:~ #
What can I do to make bluetooth work?
I hope you can help me.
I was looking for external BT and I found this one which just works out of the box only on 21NG version of CE, (toocki brand 5.1 with barrot br8651 chip).
Edited post for a guy with crappy ATV box.
x96x4 1.Bluetooth adapter not found 2.Infrared remote control does not work 3.vfd vfd cannot be displayed
CoreELEC (official): 21.0-Omega (Amlogic-ne.aarch64)
Machine model: Amlogic
CoreELEC dt-id: sc2_s905x4_4g_1gbit
I have the A95X F3 Air 2 with a S905W2 processor and 2/16 GB.
It comes with Android TV 11 installed and has working bluetooth in it.
I am running CoreElec Omega 21 from microSD , Amlogic-ne with s4_s905w2_2g and everything except bluetooth works. I searched a bit but couldn’t find an obvious cause or solution.
lsusb doesn’t show a device :
CoreELECA95X:~ # lsusb
Bus 001 Device 002: ID 0406:2814 Fujitsu-ICL Computers 2.4G Composite Devic
I don’t see much bluetooth related in the kernel output:
CoreELECA95X:~ # dmesg | grep -i blu
[ 12.291512@3] Bluetooth: bt_init: Core ver 2.22
CoreELECA95X:~ # dmesg | grep -i bt
[ 1.280410@3] unifykey: fail to obtain phy addr of shared mem
[ 3.220877@0] input: input_btrcu as /devices/platform/aml_bt/input/input1
I also noticed :
[ 1.612857@1] aml_aucpu aucpu: Direct firmware load for aucpu_fw.bin failed with error -2
[ 1.612869@1] load aucpu_fw.bin fail
[ 1.612874@1] load start_aucpu_fw fail
hi, I am not following ?
I just tested the latest nightly : CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20240816-Generic.img and it’s the same problem.
You mean about aml-w1 not working? this is a w2.
Is that the same family ? Anything we can do to get bluetooth working?
And by the way, the VFL works.
Today I tested version NG21.1.1 and found that it does not support WiFi and Bluetooth. Ne21.1.1 supports it, but my network card and Bluetooth chip are AP6275P.
May I ask if NG supports AP6275P? I have checked the update log and it shows NG ap6275p. Currently, I am using the NG night version from September 4th, and testing shows that wireless and Bluetooth are not working properly.
