Hi Folks,
looking for some help accessiong my internal storage. i have a Beelink GT1 32gb and am booting from SD.
i can only see the SD storage in Kodi file manager. i have few films and lots of music on the internal android rom and i would like coreelec to be able to see it so i can add the my music and movie folder (and some other) folders as sources in Kodi.
i read the share internal storage thread on lireelec but don’t want to do that, and couldn’t find the answer i was looking for, i just want to be able to access android internal storage from coreelec.
can anyone help?
Thanks!
Android partitions can not be read from Linux with newer devices, we specifically stopped this so people could not destroy Android installations accidentally.
OK thanks for the reply, guess i will have to settle for sharing the storage to get around and be able to access the internal ROM…
fneves
29 October 2019 10:14
#4
@anon88919003 is there anyway I can remove that? I wanted to manually install into the eMMC, I don’t mind bricking the device while trying to do so, I can restore it through amlogic usb burning tool.
You can use ceemmc on newer devices, this is our new method for internal installs, please search the forums if you need further help with it.
Maybe this works on your Beelink GT1 (Amlogic S912) to access your data on the android partition. I have used this without problems before installing CoreELEC on the internal memory to access the android partition and accelerate timeshift on Kodi clients devices.
File: /storage/.config/autostart.sh
mkdir -p /tmp/internal-storage
mount -o ro /dev/data /tmp/internal-storage
Try this before on the SSH console. After this the android partition will be in /tmp/internal-storage
(I changed rw to ro so you don’t spoil the android partition)
I have a GT-King and /dev/data does not exist.
How can I reach the eMMC file system? I have 64GB available there that I would like to use.
Write the command
df -T
from SSH and show us the result.
The output is:
Filesystem Type 1K-blocks Used Available Use% Mounted on
devtmpfs devtmpfs 1638944 4 1638940 0% /dev
/dev/mmcblk1p1 vfat 524008 205792 318216 39% /flash
/dev/loop0 squashfs 189952 189952 0 100% /
/dev/mmcblk1p2 ext4 29667193 13745779 15917318 46% /storage
tmpfs tmpfs 1922228 0 1922228 0% /dev/shm
tmpfs tmpfs 1922228 9276 1912952 0% /run
tmpfs tmpfs 1922228 0 1922228 0% /sys/fs/cgroup
tmpfs tmpfs 1922228 2228 1920000 0% /var
tmpfs tmpfs 1922228 4 1922224 0% /tmp
CoreELEC:~ # blkid
/dev/loop0: TYPE="squashfs"
/dev/system: LABEL="/" UUID="2e6c568e-1478-5a59-be01-62993f4a17fb" TYPE="ext4"
/dev/mmcblk1p1: SEC_TYPE="msdos" LABEL_FATBOOT="COREELEC" LABEL="COREELEC" UUID="2911-4504" TYPE="vfat" PARTUUID="211d02ae-01"
/dev/mmcblk1p2: LABEL="STORAGE" UUID="d64f1eca-7a63-4904-9030-3446e096b23b" TYPE="ext4" PARTUUID="211d02ae-02"
/dev/mmcblk1: PTUUID="211d02ae" PTTYPE="dos"
PS: Many thanks for your help troubleshooting this!
I also see this:
CoreELEC:~ # ls /dev/mmc*
/dev/mmcblk0 /dev/mmcblk0boot1 /dev/mmcblk1 /dev/mmcblk1p2
/dev/mmcblk0boot0 /dev/mmcblk0rpmb /dev/mmcblk1p1
But this fails:
CoreELEC:~ # mount /dev/mmcblk0 /mnt
mount: mounting /dev/mmcblk0 on /mnt failed: No such file or directory
It seems that your internal memory is in /dev/system
Try to mount with
mkdir -p /storage/internal-storage
mount -o ro /dev/system /storage/internal-storage
and then look at the directory content /storage/internal-storage
I’m not sure if the internal memory is the /dev/system.
This is what I see:
It seems to have 2GB and not the ~64GB of GT-King
CoreELEC:~/internal # ls /storage/internal
acct etc odm
bin init oem
boot init.environ.rc proc
bugreports init.rc product
cache init.recovery.amlogic.rc sbin
charger init.usb.configfs.rc sdcard
config init.usb.rc storage
d init.zygote32.rc sys
data lost+found system
default.prop metadata ueventd.rc
dev mnt vendor
CoreELEC:~/internal # df -T
/dev/mmcblk1p2 ext4 29667193 13745780 15917317 46% /storage
/dev/system ext4 2064208 1039724 1008100 51% /storage/internal
Yes, this is your internal memory. Go carefully and do not spoil anything!
Look in
/storage/internal/storage
/storage/internal/sdcard
/storage/internal/data
Sorry but something is still off. I don’t see my things there. It should be a “Droid” file system and have ~64GB. I don’t see that data there.
cubimol:
Look in
I still can’t see nothing on those folders, only files on the mount root
CoreELEC:~/internal/storage # ls -la /storage/internal/storage
total 8
drwxr-x--x 2 root 1028 4096 Dec 31 2008 .
drwxr-xr-x 20 root root 4096 Dec 31 2008 ..
CoreELEC:~/internal/storage # ls -la /storage/internal/sdcard
lrw-r--r-- 1 root root 21 Dec 31 2008 /storage/internal/sdcard -> /storage/self/primary
CoreELEC:~/internal/storage # ls -la /storage/internal/data
total 8
drwxrwx--x 2 1000 1000 4096 Dec 31 2008 .
CoreELEC:~/internal/storage # ls -la /storage/internal/emulated/0
ls: /storage/internal/emulated/0: No such file or directory
total 1629
drwxr-xr-x 19 root root 1024 Dec 8 01:34 ..
drwxr-xr-x 2 root root 4096 Dec 31 2008 acct
lrw-r--r-- 1 root root 11 Dec 31 2008 bin -> /system/bin
drwxr-xr-x 2 root root 4096 Dec 31 2008 boot
lrw-r--r-- 1 root root 50 Dec 31 2008 bugreports -> /data/user_de/0/com.android.shell/files/bugreports
drwxrwx--- 2 1000 2001 4096 Dec 31 2008 cache
lrw-r--r-- 1 root root 13 Dec 31 2008 charger -> /sbin/charger
dr-xr-xr-x 2 root root 4096 Dec 31 2008 config
lrw-r--r-- 1 root root 17 Dec 31 2008 d -> /sys/kernel/debug
drwxrwx--x 2 1000 1000 4096 Dec 31 2008 data
lrw------- 1 root root 23 Dec 31 2008 default.prop -> system/etc/prop.default
drwxr-xr-x 2 root root 4096 Dec 31 2008 dev
lrw-r--r-- 1 root root 11 Dec 31 2008 etc -> /system/etc
-rwxr-x--- 1 root 2000 1491944 Dec 31 2008 init
-rwxr-x--- 1 root 2000 1064 Dec 31 2008 init.environ.rc
-rwxr-x--- 1 root 2000 29580 Dec 31 2008 init.rc
-rwxr-x--- 1 root 2000 14857 Dec 31 2008 init.recovery.amlogic.rc
-rwxr-x--- 1 root 2000 7690 Dec 31 2008 init.usb.configfs.rc
-rwxr-x--- 1 root 2000 5646 Dec 31 2008 init.usb.rc
-rwxr-x--- 1 root 2000 511 Dec 31 2008 init.zygote32.rc
drwx------ 2 root root 16384 Dec 31 2008 lost+found
drwxr-xr-x 2 root root 4096 Dec 31 2008 metadata
drwxr-xr-x 2 root 1000 4096 Dec 31 2008 mnt
drwxr-xr-x 2 root root 4096 Dec 31 2008 odm
drwxr-xr-x 2 root root 4096 Dec 31 2008 oem
drwxr-xr-x 2 root root 4096 Dec 31 2008 proc
drwxr-xr-x 2 root root 4096 Dec 31 2008 product
drwxr-x--- 2 root 2000 4096 Dec 31 2008 sbin
lrw-r--r-- 1 root root 21 Dec 31 2008 sdcard -> /storage/self/primary
drwxr-x--x 2 root 1028 4096 Dec 31 2008 storage
drwxr-xr-x 2 root root 4096 Dec 31 2008 sys
drwxr-xr-x 13 root root 4096 Dec 31 2008 system
-rw-r--r-- 1 root root 5272 Dec 31 2008 ueventd.rc
drwxr-xr-x 2 root 2000 4096 Dec 31 2008 vendor
ffimon
8 December 2019 02:00
#18
If its an NG box ie S905x2 or S922X. Try to download the test.sh script from How to run CoreElec on internal memory eMMC on NG boxes (S905X2, S922X) having full operating Android system too
run it, it should then mount your internal emmc to the /mnt/data directory
Brilliant!!! It worked! Many many thanks!
The Android storage is then on /tmp/data/media/0
Now I just have to automate the mount on startup.
ffimon
8 December 2019 02:23
#21
Add it to your autostart.sh in the configfiles directory. If you haven’t got one you could just rename it to autostart.sh and copy it into the ConfigFiles directory
