New Order: Looking for users with no working WiFi or BT
So there are now up to tht-5 connected.
But is a LAN cable on tht-1 or tht-2 connected?
It seems not as there is no RX/TX at all on both.
What is tht-5?
tht-1 sm1_s905x3_4g_1gbit X88 Pro X3 —> No Ethernet, No Wifi Ethernet Connected
→ WiFi/BT is SP6255 - clone of AP6255 driver BCM43455C0 for wifi.
tht-2 sm1_s905x3_4g_1gbit H96 Max X3 —> No Ethernet, No Wifi
HK5235f wifi chip
tht-3 sm1_s905x3_4g Tanix TX5 Pro —> No Wifi
tht-4 g12a_s905x2_4g H96 Max X2 ----> No Wifi
tht-5 sm1_s905x3_4g A95X F3 Air -----> No Wifi MT7668RSN Chip
LAN cable is connected on tht-1 or tht-2?
We did hit already the connection limit again. It’s maybe because the drivers do connect/disconnect whole time.
Please tomorrow only connect back tht-3. I currently try to port the old 4.9 driver to 5.15.
EDIT: @tht please leave tht-3 online. I still can connect as I have the connection id already for today.
Will do, Do you want to leave the current sdcard in it, on boot up it never gets past the splash screen
tht-3 will be back online tonight for me.
This tht-3? It did boot but disappeared later. It must have this 4330 chip.
I will put a fresh copy of the 03042024 no on it before I return it online
And yes the chip is AP6330 using fw_bcm40183b2.bin firmware
And please use the generic image. On one device I have seen boot.ini and this is only for devices with u-boot included.
@tht looks like the device is not booting anymore. Please try to get it working again, thx!
Regarding the MT7668 WiFi/BT chipset. I’m not sure which drivers have been tried so far. The PS4 mod version should have working WiFi, and BT BR/EDR functionality.
The last modification to the BT driver replaced the PS4 version with the FireOS version which didn’t cause kernel crashes in 4.9. The PS4 BT version should work on 5.15.
The PS4 mod is really just this source
mt7668-bluetooth-mod - Git at Google (unmodifed & already worked with 5.15)
mt7668-wifi-mod - Git at Google (modified to work on 5.15)
This is the original PS4 wifi/bt version that @shanti prepared for EE/CE that I think is ready to compile for 5.15
mt7668-wifi-bt-main.zip (3.1 MB)
It did reboot but ethernet didn’t make, I rebooted it again this time ethernet is working.
Tht-3 had lan before!? Internal 100mbit. I am working on wifi. Please ensure to set correct user name and bring it up.
Rebooted it again the user is set to tht-3, I brought up another box on tht-3.2 same hardware as
tht-3 so there are now 2 of the same boxes running
Hear is a List of hardware that should run on the no builds
X96s S905y2 2gb/16gb Android Stick
A95X F2 s905x2 4gb Ampac wifi ap6212 working wifi
H96 Max X2 s905x2 4gb/64gb Ampac ap6330 Not Working
A95X F2 s905x2 4gb mediatek wifi —> At my Summer Residence.
Magicsee N5 Max s905x2 4gb —> At my Summer Residence.
Transspeed X3 s905x3 4gb/32gb gigbit ethernet wifi not working ethernet not working either
X88 Pro X3 / X99 Max Plus / Transpeed X3 Plus TV Box has same board,
A95X F3 Air s905x3 4gb/64 wifi not working MT7668RSN
H96 Max X3 s905x3 4gb/128gb not working wifi chip → AP6335
Tanix TX5 Pro 4gb No Wifi
NinkBox N8 Plus s905x3 4gb/32gb aka “Tanix TX5 Pro” Clone No Wifi
X96 Max+ s905x3 4gb/32gb gigabit ethernet rtl wifi chip All networks Work
Libre Alta a311d 4gb working
Khadas
Vim3l s905d3 2gb working
Vim3 a311d 2gb working
Vim4 a311d2 8gb working
ODroid
N2+ s922x 4gb
C4 s905x3 4gb —> At my Summer Residence.
X96 X4 s905x4 4gb/32gb network working
Beelink GT-King s922x 4gb/64gb working
I would like to come back to this problem, it is different on the new DTS, but wifi still does not work. After a few tries, I used this script autoexec.sh and I have WiFi:
#!/bin/sh
# change GPIO_ACTIVE_HIGH to GPIO_ACTIVE_LOW for sys_led
new_val=$(fdtget -t i /flash/dtb.img /gpioleds/sys_led gpios | sed "s|\([0-9]*\) \([0-9]*\) .*|\1 \2 0|")
if [ -n "$new_val" ]; then
	mount -o remount,rw /flash
	fdtput -t i /flash/dtb.img /gpioleds/sys_led gpios $new_val
	fdtput -t i /flash/dtb.img /sd2@ffe05000 max-frequency-sdio 40000000
	sync
	mount -o remount,ro /flash
fi
modprobe 8189fs
I can’t solve it any other way.
tht-3 is not online anymore and tht-3.2 did not come up after update anymore.
I think I would need a UART log of one of these with the update from here:
dhd-4330 test image.
I think it will crash so I can’t look into dmesg.
I did the update on tht-3 after reboot had to stop and restart tmate it had failed
tht-3.2 should also be online no update on that one.
Both devices are now down. I have no idea how to fix it without physical touch it.
The driver is just written for 4.9 and it compiles for 5.15 now. But this does not mean it works at all…
This is the uart log for the tht-3-2
Maybe it will help
https://paste.kodi.tv/woyedacobe.kodi
If not where would I send the box too
Nice, the firmware gets now loaded. But like as expected something else needs to be fixed.
Can you bring the devices back up with nightly image?
At least one of it, thx.
I have one back online, Working on the other
The other one is back online
You should see two of them.
