Thanks, this plugin is solved with
How to set 1080p resolution in Amazon Prime ?
Buy a Amazon certified device, their ecosystem it’s locked. Like HboVaxx, no HD resolution possible.
Yes, right now with the main streaming addons it’s Netflix 1080p (S922x or with S905x3 and low bitrate), Disney + 720p, Amazon and HBO max SD.
Just updated N2 to last Nexus nightly ( 20220409) and have one question:
How do I change “Display Refresh rate” on this version?
Since one of the last updates I cannot change the refresh rate in the System/Display settings
So The refresh rate is allways in 60 HZ mode
Hello
I just downloaded the latest update 20220416 and I still have this display problem on Hdr movies on my Sdr Tv.
This issue appeared since Matrix 19.4 rc2
On the other hand, HDR10+ and Dolby Vision films are displayed well on my Tv Sdr.
See this post
Thanks for the work you do.
Regards
Hello
My problem is only in kodi20 nightly in kodi 19.4 everything is ok
I dont usd HDR
Which was the last one where it was still available? What’s wrong with 60Hz?
Hello
For me 50 Hz is usefull because i use my boxes mostly to look TV and Content in 50Hz
With 60Hz my TV toggle between the refresh rates
I have only an older kodi20 nightly Image from 20220121 saved
And with this image I can change the resolution and the refresh rate like in 19.4
With the new nightly Kodi 20 update I can only change the resolution
You can set boot resolution to 1080p50hz in “config.ini” and then it stay the same in GUI:
-# VOUT mode
-# You can use this setting to set a specific video mode at boot.
vout=‘1080p50hz’
Thank you Sholander, that works
If I had to guess °F.
That would be close (45°C) to 38°C CPU temp, but it’s also missing " °F ".
Anyway, since CPU&GPU share the same enclosure, it’s unusual that the temperature can be whole 7°C higher.
Actually both values are the same and shows SoC temperature.
But because there is update interval the second value is probably different.
And actually there should be only one line. Will be fixed soon.
OK, that’s what I thought; shouldn’t it then be labelled as “SoC temperature” to be more precise?
And what about missing “Display Refresh rate” value as shown on picture in post no. 2030?
Refresh rate should be back with next nightly Nexus 20220420.
Anyone else has a problem with audio after stop/pause not the out of sync problem but it sounds like robots talking? Stop is not helping only reboot.
I hope that log is ok - started after second pause of futurama then stop and play other files but still same error.
There is something wrong:
2022-04-27 11:53:44.430 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/pcm/pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
2022-04-27 11:53:44.430 T:3725 INFO <general>: CAESinkALSA - Unable to open device "surround51" for playback
2022-04-27 11:53:44.431 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/pcm/pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
2022-04-27 11:53:44.431 T:3725 INFO <general>: CAESinkALSA - Unable to open device "surround40" for playback
2022-04-27 11:53:44.431 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/pcm/pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
2022-04-27 11:53:44.431 T:3725 INFO <general>: CAESinkALSA - Unable to open device "surround51" for playback
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/confmisc.c:767:(parse_card) cannot find card '$CARD'
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:4745:(_snd_config_evaluate) function snd_func_card_driver returned error: No such device
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/confmisc.c:392:(snd_func_concat) error evaluating strings
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:4745:(_snd_config_evaluate) function snd_func_concat returned error: No such device
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/confmisc.c:1246:(snd_func_refer) error evaluating name
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such device
2022-04-27 11:53:44.440 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5233:(snd_config_expand) Evaluate error: No such device
2022-04-27 11:53:44.444 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5084:(parse_args) Unknown parameter CARD
2022-04-27 11:53:44.444 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2022-04-27 11:53:44.444 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5200:(snd_config_expand) Unknown parameters CARD=AMLAUGESOUND,DEV=0
2022-04-27 11:53:44.444 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5084:(parse_args) Unknown parameter DEV
2022-04-27 11:53:44.445 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2022-04-27 11:53:44.445 T:3725 INFO <general>: CAESinkALSA - ALSA: /var/corebuild/CoreELEC-19/build.CoreELEC-Amlogic-ng.arm-19/build/alsa-lib-1.2.4/src/conf.c:5084:(parse_args) Unknown parameter DEV
Can you try with a clean install. Just use another uSD or USB device and make a clean install with the last nightly available.
