Nightly builds (NEW)
It’s needed to boot Android once after flashing with USB burning tool! On first boot the super partition get adjusted. When Android did boot just power it off and perform CE install steps as usual. Maybe you missed this step.
A post was merged into an existing topic: Amlogic S928X
The last ne nexus night builds disabled pvr and sftp addons?
All good here with sftp addon and pvr iptvsimple.
I will try a fresh install to see if it different
Hi, everybody
Hotbird Satellite 12380 V 30000 Frequency Fashion TV UHD Channel Black Screen. Other channels with the same frequency work without problems. It works if the FTV UHD channel is being recorded. The channel is unencrypted FTA .
If a time shift is made in the recording, it works again. I had the same problem again when I tried it with Kodi on Android.
Is this problem on the Kodi side or on the Tvheadend side? I tried it with TVH 42 and TVH 43.
Could this problem also be on the side of CoreELEC?
Can you test this channel?
Best regards…
Is the latest nightly 20231008 broken?
It will not boot up … back to 0927 and it’s all fine.
I have repeated 2 times and it’s always the same.
Same here. Error from the kodi service’s log:
/home/docker/build_dir/CoreELEC-21/build.CoreELEC-Amlogic-ne.aarch64-21/toolchain/aarch64-libreelec-linux-gnu/sysroot/usr/lib/libGLESv2.so: cannot open shared object file: No such file or directory
Left over path from the build maybe?
At least it’s easy enough to rollback by putting the previous tar in /storage/.update
Same problem hanging on coreelec splash screen on my S905Y4/4GB
Same happened on my S905X4 HK1 RBOX X4 both on update and clean install. Thanks for reporting the issue!
Heads up that the mods might want to disable cue support if coreelec repos use libecue untill a patch is pushed or backported into release.
Or post a sticked announcement
A post was merged into an existing topic: Report about Amlogic S905X4 HK1 RBOX X4
so i have been on CE 20 NE on my Homatic 4K Plus for a while no, but i never get notifications to update to the latest nightly, i always have to manually update, updates are set to auto
it doesn’t work for me either, with exception of major release upgrades, like the alpha3 to beta1 couple days ago (if that can be considered as major release). otherwise I think auto updates in nightly builds don’t work on purpose.
Interesting, it has always worked on my HK1-RBOX-X4.
Update system looks normal, no log no problem:
well, since 21.0-Omega beta1 (last 2 updates), it is working automatically again. Before, I always had to wget .tar manually and reboot, despite all auto update options were set to “on”. anyway, glad it is working.
not sure how a log would help here, the auto update simply does not work. i would imagine it has something to do with ne, ng, 20, 21 folders.
but here you go:
http://ix.io/4JQ0
anyone look at this?
Because you are already on last nightly 20.3-Nexus_nightly_20231024?
