i updated manually, as i stated above. i can roll back and turn logs back on and reboot if you want. im was waiting for direction on troubleshooting but got nothing!
is there a command i can run to invoke the update?
Is there an issue in latest nightly that pictures are not shown correctly? Some covers and fanart has green bars at the bottom. Pictures from picture folder on Nas with same problems. Not the whole collection but the most. Most files are jpeg…
With other devices running Kodi on Android TV all fine with the same mount and files.
I’ve noticed with latest nightly with CE NE 21 on Dune HD Box R4k+ . Not sure if it’s also on previous version , but last week everything was ok at viewing pictures…
Someone else with that issue?
Edit:
I think the issue is only on preview. Viewing the pictures on full screen it’s ok.
Scaling ore zooming issue?
Tried mid August to use latest nightlies. Since then tried several more. Today again. All give me the error:
HTSP Client:
No free adapter available.
I have no problems with CoreELEC 20.2-Nexus Amlogic-ng.
This is strange and holding me from enjoying latest nightlies on my Mecool Ki Pro Box (S905D). reflashing to 20.2 will fix it.
It would be great to have an updated version of the Zattoo PVR Client included in the builds. Recently the Zattoo PVR Client received a couple of updates in the area of DRM options.
Hi, I’m on CoreELEC-Amlogic-ng.arm-21.0-Omega_nightly_20231218 on a s905x2. Every time I try to play a video with ACC audio, the player closes after a few seconds. Somebody could help me?
2023-12-28 02:21:04.166 T:3859 info : CVideoPlayer::CloseFile()
2023-12-28 02:21:04.166 T:3859 info : VideoPlayer: waiting for threads to exit
2023-12-28 02:21:04.168 T:6163 info : CVideoPlayer::OnExit()
2023-12-28 02:21:04.168 T:6163 info : Closing stream player 1
2023-12-28 02:21:04.168 T:6163 info : Waiting for audio thread to exit
2023-12-28 02:21:04.198 T:6166 info : thread end: CVideoPlayerAudio::OnExit()
2023-12-28 02:21:04.198 T:6163 info : Closing audio device
2023-12-28 02:21:04.247 T:3889 info : CActiveAESink::OpenSink - initialize sink
2023-12-28 02:21:04.248 T:6163 info : Deleting audio codec
2023-12-28 02:21:04.248 T:6163 info : Closing stream player 2
2023-12-28 02:21:04.248 T:6163 info : waiting for video thread to exit
2023-12-28 02:21:04.265 T:6165 warning : OutputPicture - timeout waiting for buffer
2023-12-28 02:21:04.265 T:6165 info : thread end: video_thread
2023-12-28 02:21:04.266 T:6163 info : deleting video codec
2023-12-28 02:21:04.286 T:3859 info : VideoPlayer: finished waiting
2023-12-28 02:21:04.286 T:3859 info : CVideoPlayer::CloseFile()
2023-12-28 02:21:04.286 T:3859 info : VideoPlayer: waiting for threads to exit
2023-12-28 02:21:04.447 T:3889 info : CAESinkALSA::Initialize - Attempting to open device “@”
2023-12-28 02:21:04.453 T:3889 info : CAESinkALSA::Initialize - Opened device “sysdefault”
2023-12-28 02:21:04.453 T:3889 info : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-12-28 02:21:04.453 T:3889 info : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-12-28 02:21:04.736 T:3859 info : GLES: Maximum texture width: 8192
Audio not working since latest nightly Ne build there’s only one audio now PULSE:Default, Bluetooth Audio(PULSE AUDIO), there’s no other audio in pull down audio does not play
Hi how do I get the audio working now?
Wait for next build or revert with manually updating previous build.
https://relkai.coreelec.org/?dir=Amlogic-ne/ce-21/archive
thankyou i’ve reverted back all working againg now thanks will it be fixed in next nighlty?
I install ng nexus 20.3 nigtly on a X4 Box
but deinterlacing dont work
With 1080i I have a flickering picture
I have installed some addons, added my sources through the network via NFS from my win10 machine (for some reason i cant find it with samba) anyway.
After scanning for about an hour or 30 minutes corelec just hangs.
Log: paste.coreelec.org/1Cb2nU
I have no idea how to decipher these logs
This issue is caused by LibreELEC: Switch to util-linux's mount/umount programs by HiassofT · Pull Request #8497 · LibreELEC/LibreELEC.tv · GitHub
A fix is in work and hopefully merged soon.
Is this issue on stable as well? I downgraded to stable and it still hangs/freezes
Uhm so i put the exact link for update file in custom channel And now i can’t enter coreelec settings
What channel do i put to be able to update to nightly directly from coreelec?
Getting black screen on Jan 30th nighty build “ne” after the update(coreelec splash screen shows then screens turns black), rolled back to beta2 release.
