What tuner, what addon, what driver?
Run NE and post lsmod | paste with the tuner attached please.
NE 09-10-2024 AM8
https://paste.coreelec.org/LathamVince
NO 08-10-2024 GT KING II
https://paste.coreelec.org/MacbethDevlin
I have two separate USB tuners.TBS 5520SE and TBS 5530
Boot without the tuner and run this on SSH:
journalctl -f -o short-precise -k > /storage/backup/dmesg.log
Then plugin the tuner.
After reboot remove the tuner and share the dmesg.log like by cat /storage/backup/dmesg.log | paste.
Or do you have UART access to any CE NO device where you can make a log?
Now boot without attached tuner and then open one SSH terminal and type this command
dmesg -c ; while [ true ]; do dmesg; done
after that attach tuner and box will reboot. Copy/paste text you got to hastebin.
The system shuts down as soon as the tuner is installed
Ok, then maybe we will figure out ourself.
This appeared on SSH
[ 1086.250099] usb 3-1.2: new high-speed USB device number 3 using xhci-hcd
[ 1086.402505] usb 3-1.2: New USB device found, idVendor=734c, idProduct=5530, bcdDevice= 0.01
[ 1086.402522] usb 3-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1086.438553] dvb-usb: found a 'TurboSight TBS 5530' in cold state, will try to load a firmware
[ 1086.445993] dvb-usb: downloading firmware from file 'dvb-usb-id5530.fw'
[ 1086.446014] tbs5530: start downloading tbs5530 firmware
[ 1086.508397] usb 3-1.2: USB disconnect, device number 3
[ 1086.558467] dvb-usb: found a 'TurboSight TBS 5530' in warm state.
[ 1086.558840] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1086.558848] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1086.558954] DVB: registering new adapter (TurboSight TBS 5530)
[ 1086.558962] tbs5530: read eeprom failed.
[ 1086.558964] dvb-usb: MAC address reading failed.
crazyturk, please try this image: 323.34 MB file on MEGA
Did not work.
TBS 5520SE
TBS5530
My friend has two tuners, one is TBS5520SE and the other is TBS5930.
TBS5930 works smoothly with NO version but TBS5520SE doesnât work like mine and reboots.I think there is a mismatch with usb voltages.All usbs work except tuner.
But it did work before or not?
This is another test message. Please do same procedure as before.
Thanks,It didnât work in this software. I made pastebin twice
I tested the same software on 3 different devices and got the same result on all 3.
GT King Pro, GT King II and Ugoos AM8
USB TBS tuner turns off when I plug it into 3 devices.My tuners are TBS5520SE and TBS5530.
My friend has TBS5930 and TBS5520SE tuners, TBS5930 works without any problem but not with TBS5520SE.
Please make a dmesg | paste when connect tuner after boot up with nightly 20241008.
We did switch the compiler for the kernel to be compatible with Amlogic-no DV in future.
08-10-2024 CE NO
https://paste.coreelec.org/PlasticVirile
I installed todayâs 20241011 and the device turned on with the tuner plugged in. When I check the system does not recognize the tuner.
I went back to the software 20241008 and tmate is open.
Device AM8
Note:I just tried todayâs software on King II and it wonât turn on with the TBS5530 tuner plugged in.
My friendâs AM8 with TBS5930 tuner plug and working.
Would you like me to enable tmate (enable terminal sharing) on my other working gt king ii?
TBS5530 tuner installed.
