UPDATE:
Just tried it with build 20191224 - Same issue.
This does not appear to be the same thing @frodo19 was reporting as the boot screen and CE splash always appear and display is there up until just after the build # is shown but the display signal is lost when the GUI is supposed to appear. The box is running and responds to SSH and remote, but no video signal.
I have a problem with my tp link ue330 (usb-ethernet adapter Gbit usb hub) in NEW nightly build, kernel 4.9.113. It is unmounted and remounted very often at the storage units connected to the USB hub when there is traffic on the network cable. Sometimes it even freezes the box and must be powered of and on. This does not happen in stable version kernel 4.9.190. I also tried 3A power supply, on two devices, a s905x2 and a s905x3 (thatâs only with CE nightly).
Some infos from stable build:
CoreELEC:~ # lsusb
Bus 002 Device 003: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapte r
Bus 002 Device 005: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2
Bus 002 Device 004: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, A SM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 1915:1025 Nordic Semiconductor ASA
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
CoreELEC:~ # dmesg |grep -i eth1
[ 5.936680@1] r8152 2-1.4:1.0 eth1: v1.09.10
[ 6.331963@2] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 9.229492@3] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 9.231741@3] r8152 2-1.4:1.0 eth1: carrier on
Some infos from nightly build:
CoreELEC:~ # lsusb
Bus 002 Device 005: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 002 Device 004: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2
Bus 002 Device 003: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
[ 7.592998@1] r8152 2-1.4:1.0 eth1:v1.08.9
[ 7.624951@1] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 10.906747@3] r8152 2-1.4:1.0 eth1: carrier on
[ 10.906809@3] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Can anyone tell me if there will be no more nighly updates builds for SoC S905/S912, there are no updates in the repository and my box has not been able to update for days.
I updated my Vim3l to CoreELEC-Amlogic-ng.arm-9.2-nightly_20191224-Generic.img.gz. It is working much better than the original install, especially with HD audio. I am having issues with aspect ratios. All the movies play in stretched 16:9. If I try and choose another ratio manually nothing happens.
Thatâs it? 9.2.1 is the final release and there is nothing further for these boxes? I thought cdu13a was preparing a 4.9 release to align them on the same path as the ng platforms. How about Kodi 19?
Sorry that is not true, there has been a build error with âAmlogicâ releases and thats why there has been no nightly release, it should resume again tomorrow as this has now been fixed.
I had already left the forum for a few days when it was said that there is nothing at the moment for (S905D).
But I came back here today, and found good news.
Awaiting the test image, for my KI Pro.
i have x96max plus(s905x3 4g/ 32g/ gigabit/ bluetooth)
i had tested nightly build( CoreELEC-Amlogic-ng.arm-9.2-nightly_20191224.tar, s905x3 4g gigabit.dtb)
Wifi - 2.4 GHz canât remember password, canât connect
Wifi - 5 GHz - connection attempt restarts the box BT- work perfect
Remotr controll - red button power off work perfect but cannot be turned on ()
