What image I download for a S905X3?
NG? BTW NG meaning what? New generation?
290a serial here
It wonât be available until TOMORROW!
Amlogic-ng (Next generation)
290a serial here too
Mine /proc/cpuinfo
Serial : 290aâŚ
model name : Amlogic S922X rev a
Hardware : Beelink GT-King
Revision : 0400
Just applied the 20191217 update (rom 20191215) to my S905X2.(A95X Max)
The good news is that the Xbox TV Tuners are now being seen.
The bad news is that whatever I play, there is no video, only audio and this applies to streaming, local files and live TV.
I also note that whist anything is playing, every 6 seconds the seeking prompt pops up at the top of the screen for around 2 seconds before disappearing and the process repeating continually.
Vim3L HTPC Version.
Updated to CoreELEC-Amlogic-ng.arm-9.2-nightly_20191217.tar
No issues with playback Movie Files / TVH Client recordings and Live TV.
(Server is on a seperate box TX7 Running old LE Krypton with old TVH Server)
@Compent can you edit above post to name your box.
@Compent already fixed for tomorrowâs nightly, just disable DVB driver addonâs for now and playback will work again.
+1 to @Compent. My tvh server wouldnât run with previous version. It does with the latest but no video on anything unless I disable hardware acceleration. With it disabled video is in slo mo and out of sync with audio. Box is H96 Max X2 4/32.
@sonofdibnah please refer to my above post.
S905X2 can not handle SW decoding hence the poor playback when you disable h/w acceleration, only S922X and A311D can manage SW decoding.
Thanks for the update.
@OlpioFort @Keltek @anon26735799 please try the device tree here.
Thanks @anon88919003. We must have been posting at roughly the same time because I hadnât seen yours.
VONTAR S905X3 4Gb/32Gb BT., 1000Mbit Dual WIFI: nenwork - onli static ip ,network - no, wifi - no, but starting!!!
âsm1_s905x3_4g_1gbit.dtbâ
@filkint if you have no network then you selected the wrong dtb.
X96MAX plus s905x3 4g/32g/1000M, the network is ok, but the wifi is no.
the IR poweroff and wake up work all.
the playback is nice perfectly.
thank your hard work.
Wifi support is not guaranteed, it is dependant on what chip you have in your device.
Paste the output of udevadm info /sys/bus/sdio/devices/sdio* | paste
Unknown device â/sys/bus/sdio/devices/sdio*â: No such device
use 2 dtb.
Latest nightly 17th on my VIM3L HTPC Version i just picked up a strange bug on only one of my Free to Air HD channels using TVHeadend Client.
I have constant video jitters during playback.
EDIT: I rolled back to Nightlies 14th December and 15th December
Same issue on both Nightlies.
I was on the release version November and am pretty sure this wasnât apparent then.
Player Debug Info screen I see Pullup correction pattern length of PC:2 in the codec window.
All other channels are PC:1
**Checked the same channel using my H96Pro S905X Dongle using 9.2.1 Stable **
and that shows PC:1
dmesg|pastebinit
http://ix.io/24L9
