I did it right away.
Still see 20200104 build:
And my box still informs about new update. Fortunatelly i changed to manual update.
You only see the ng and those are fine.
Thank You.
And sorry for mess.
As I understand the difference between the builds from “20210103” and “20210105” does not exist?
CoreELEC nightly 2021/01/06 successfully updating and booting from:
- TaNix TX5 Deluxe Edition (905X3)
- Turewell F2 A95X (S905X2)
- TaNix TX3 MAX (S905W)
- NexBox A95X-B7N (S905X)
Are scripts behind relkai.coreelec.org available somewhere, git repo maybe? Or build logs for entire process?
I’m for example interested in which commands are used to build odroid n2 armlogic-ng images.
@arek it’s basically the following wrapped in some checks to see if there has been an update, and to generate the changelog and add it to the img.
git clone https://github.com/CoreELEC/CoreELEC.git
cd CoreELEC
PROJECT=Amlogic-ng ARCH=arm make image
And other targets?
Would be nice if build logs, including commands, ended up also on relkai.
If you want to build for the devices supported by the Amlogic builds then it’s the same except you change PROJECT=Amlogic-ng to PROJECT=Amlogic
Is there a particular reason you want the build logs?
Ok, thanks.
buildlogs - to compare my build logs (and I have build errors) with “working” (as building fine) nightly builds
Maybe if you open a new thread about the build problems you are having then somebody might be able to help figure out the problem you are having.
I’ll figure on my own (and if not then I’ll do that).
Just saying that logs make sense for other people, too.
Look at how linux distros are doing that, https://koji.fedoraproject.org/koji/, https://buildd.debian.org/
How to enable verbose build and disable parallel build?
So far was playing with these options but all didn’t work:
PKG_VERBOSE_TARGET_ENABLED=1 PROJECT=Amlogic-ng ARCH=arm make image
PKG_BUILD_FLAGS="+verbose -parallel" PROJECT=Amlogic-ng ARCH=arm make image
MAKEFLAGS=“V=1 VERBOSE=1” PROJECT=Amlogic-ng ARCH=arm make -j1 image
CONCURRENCY_MAKE_LEVEL=1
And even with parallel build you get log for each package in folder build.CoreELEC*/.threads/logs.
And verbose? VERBOSE=yes doesn’t work (bl301 build for example is built without verbose in such case). For now I always enabled it in config/functions to see what’s going on while building.
Btw. which distro at which version is recommended for building coreelec?
(I’m using one with latest versions of software and building here is a pain; I needed to fix/update tons of packages and I’m still not getting full build)
I can say that I use ubuntu 20.04 for building and I rarely face any problems.
It seems to me that the EPG is updated very often.
http://ix.io/2Lvl
P.S. The refresh rate is set to 180 minutes.
Try to change it to different value and return back and reboot your box
Don’t see any problems, may be some addon asks to update epg
I am using the 2021.01.08 nightly build. Before this build everything worked fine but now the big files are stutters. These are only full hd movies, 25GB-35GBs files. No matter where I store them in the network: on my computer or on my NAS. Will you fix it or I have to try the stable version of CE?
Device: H96 MAX X3 Android 9.0 TV Box 4GB 64GB Amlogic S905X3 Quad core
Here are the details of one of the file:
*rouge one remux:*
*Format : Matroska*
*Format version : Version 4*
*File size : 34.2 GiB*
*Duration : 2 h 13 min*
*Overall bit rate mode : Variable*
*Overall bit rate : 36.6 Mb/s*
*Encoded date : UTC 2017-04-14 04:58:55*
*Writing application : mkvmerge v8.0.0 ('Til The Day That I Die') 64bit*
*Writing library : libebml v1.3.1 + libmatroska v1.4.2*
*Video*
*ID : 1*
*Format : AVC*
*Format/Info : Advanced Video Codec*
*Format profile : High@L4.1*
*Format settings : CABAC / 4 Ref Frames*
*Format settings, CABAC : Yes*
*Format settings, Reference frames : 4 frames*
*Codec ID : V_MPEG4/ISO/AVC*
*Bit rate mode : Variable*
*Bit rate : 33.8 Mb/s*
*Maximum bit rate : 35.5 Mb/s*
*Width : 1 920 pixels*
*Height : 1 080 pixels*
*Display aspect ratio : 16:9*
*Frame rate mode : Constant*
*Frame rate : 23.976 (23976/1000) FPS*
*Original frame rate : 23.976 (24000/1001) FPS*
*Color space : YUV*
*Chroma subsampling : 4:2:0*
*Bit depth : 8 bits*
*Scan type : Progressive*
*Bits/(Pixel*Frame) : 0.680*
*Stream size : 31.6 GiB (92%)*
*Title : HyperX*
*Language : English*
*Default : Yes*
*Forced : No*
*Audio #2*
*ID : 3*
*Format : DTS XBR*
*Format/Info : Digital Theater Systems*
*Commercial name : DTS-HD High Resolution Audio*
*Codec ID : A_DTS*
*Bit rate mode : Constant*
*Bit rate : 2 046 kb/s*
*Channel(s) : 8 channels*
*Channel layout : C L R LFE Lb Rb Lss Rss*
*Sampling rate : 48.0 kHz*
*Frame rate : 93.750 FPS (512 SPF)*
*Bit depth : 24 bits*
*Compression mode : Lossy*
*Stream size : 1.91 GiB (6%)*
*Default : No*
*Forced : No*
