Updated on Coreelec-Amlogic. arm-9.2-nightly_201229, how to enable zram?
Here you can find instruction for autostart.sh
Only one zram disk is created 256M
Try to execute commands one by one and check the output if it has some errors
there are errors, but I canāt provide them right now, sorry.
maybe Iāll do it laterā¦
2020-12-29T21:00:00Z
CoreELEC (official): nightly_20201230 (Amlogic.arm)
CoreELEC:~ # modprobe zram num_devices=4
CoreELEC:~ # echo 256M > /sys/block/zram0/disksize
CoreELEC:~ # echo 256M > /sys/block/zram1/disksize
-sh: can't create /sys/block/zram1/disksize: nonexistent directory
CoreELEC:~ # echo 256M > /sys/block/zram2/disksize
-sh: can't create /sys/block/zram2/disksize: nonexistent directory
CoreELEC:~ # echo 256M > /sys/block/zram3/disksize
-sh: can't create /sys/block/zram3/disksize: nonexistent directory
CoreELEC:~ # mkswap /dev/zram0
Setting up swapspace version 1, size = 268431360 bytes
UUID=289b6fb4-1f9e-4d8f-bb7b-bba337ba0249
CoreELEC:~ # mkswap /dev/zram1
mkswap: can't open '/dev/zram1': No such file or directory
CoreELEC:~ # mkswap /dev/zram2
mkswap: can't open '/dev/zram2': No such file or directory
CoreELEC:~ # mkswap /dev/zram3
mkswap: can't open '/dev/zram3': No such file or directory
CoreELEC:~ # swapon -p 10 /dev/zram0
CoreELEC:~ # swapon -p 10 /dev/zram1
swapon: cannot open /dev/zram1: No such file or directory
CoreELEC:~ # swapon -p 10 /dev/zram2
swapon: cannot open /dev/zram2: No such file or directory
CoreELEC:~ # swapon -p 10 /dev/zram3
swapon: cannot open /dev/zram3: No such file or directory
CoreELEC:~ # swapon -s
Filename Type Size Used Priority
/dev/zram0 partition 262140 0 10
i had an update today which had a freaking long changelog (84 pages or so).
i guess that was an error. can someone provide the corrected changelog?
filkint, I think there is already some ram used and you can use only free ram.
Try to stop kodi first:
free -m
systemctl kodi stop
... and all other commands
free -m
I think nothing was updated from last time. Could be some error with build script.
CoreELEC (official): nightly_20210102 (Amlogic.arm)
CoreELEC:~ # htop
CoreELEC:~ # free -m
total used free shared buff/cache available
Mem: 803 170 363 11 269 570
Swap: 0 0 0
CoreELEC:~ # systemctl stop kodi
Mem: 803 91 441 11 270 649
Swap: 0 0 0
UUID=386e6360-443f-4c0d-a963-811b5fc4618d
Mem: 803 82 450 11 270 658
Swap: 255 0 255
P.S. Can I add an lz4 compressor?
As you can see you have only 441 MB free ram. And you can create only one 256 MB block for zram. Try higher size or use 2 smaller blocks.
For lz4: before settings size set the algorithm with
echo lz4 > /sys/block/zramX/comp_algorithm
you can check it with
cat /sys/block/zram0/comp_algorithm
and you get result
lzo [lz4] deflate lz4hc 842
LZ4 is enabled only on Amlogic-ng project.
CoreELEC (official): nightly_20210103 (Amlogic.arm)
CoreELEC:~ # modprobe zram num_devices=1
CoreELEC:~ # echo lz4 > /sys/block/zram0/comp_algorithm
-sh: canāt create /sys/block/zram0/comp_algorithm: Permission denied
CoreELEC:~ # cat /sys/block/zram0/comp_algorithm
cat: canāt open ā/sys/block/zram0/comp_algorithmā: No such file or directory
Ah, LZ4 is not enabled on Amlogic project: https://github.com/CoreELEC/CoreELEC/blob/coreelec-9.2/projects/Amlogic/linux/linux.aarch64.conf#L139
It is available only on Amlogic-ng.
CoreELEC:~ # echo lzo > /sys/block/zram0/comp_algorithm
filkint, LZ4 is enabled and works only on Amlogic-ng project. In Amlogic is disabled.
I know that, I donāt know why?
Because no one was using it.
It will be available in next nightly build.
Updated to CoreELEC-Amlogic.arm-9.2-nightly_20210104, hanging on the logo.
Yes, seems CoreELEC-Amlogic.arm-9.2-nightly_20210104 is bad and doesnāt boot
Yes, the nightly got removed to prevent update to 20200104.
For those who already updated please download last working nightly:
https://relkai.coreelec.org/archive/CoreELEC-Amlogic.arm-9.2-nightly_20210103.tar
Replace on your CE boot media the files kernel.img with KERNEL and SYSTEM with SYSTEM from the tar located in the subfolder target. Please rename KERNEL to kernel.img again. CE should boot normally again without any loss of data.
The copy of the md5 files is not necessary.
