when i use 115200 i get no output at all
edit: my bad, had to restart, made a big update, guess something was messed up (libs etc.)
here is the log
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.02.21 23:00:52 =~=~=~=~=~=~=~=~=~=~=~=
[ 327.929976@0] [5210]: Failed to unmount /flash: Device or resource busy
[ 327.939853@0] [5211]: /usr/lib/systemd/system-shutdown/disk-park.sh failed with exit status 1.
[ 327.943340@0] systemd-shutdown[1]: Failed to finalize file systems, loop devices, ignoring.
[ 328.107068@2] leds input1::numlock: led_trigger_set: Error sending uevent
[ 328.108242@2] leds input1::capslock: led_trigger_set: Error sending uevent
[ 328.115098@2] leds input1::scrolllock: led_trigger_set: Error sending uevent
[ 328.122121@2] leds input1::kana: led_trigger_set: Error sending uevent
[ 328.557865@0] reboot: Restarting system
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd 1.
G12B:BL:6e7c85:7898ac;FEAT:E0F83180:402000;POC:F;RCY:0;EMMC:0;READ:0;0.
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:0000c067
L3:14000020
B2:00402000
B1:e0f83180
TE: 94348
BL2 Built : 06:17:13, Jun 28 2019. g12b gf0505d7-dirty - qi.duan@droid13
Board ID = 4
Set A53 clk to 24M
Set A73 clk to 24M
Set clk81 to 24M
A53 clk: 1200 MHz
A73 clk: 1200 MHz
CLK81: 166.6M
smccc: 0001b868
eMMC boot @ 0
sw8 s
DDR driver_vesion: LPDDR4_PHY_V_0_1_14 build time: Jun 28 2019 06:17:09
board id: 4
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from eMMC, src: 0x00030200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from eMMC, src: 0x0002c200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
fastboot data verify
verify result: 255
Cfg max: 2, cur: 1. Board id: 255. Force loop cfg
DDR4 probe
ddr clk to 1320MHz
Load ddrfw from eMMC, src: 0x00014200, des: 0xfffd0000, size: 0x0000c000, part: 0
00000000
emmc switch 0 ok
Check phy result
INFO : End of initialization
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of write delay center optimization
INFO : End of read delay center optimization
INFO : End of max read latency training
INFO : Training has run successfully!
1D training succeed
Load ddrfw from eMMC, src: 0x00020200, des: 0xfffd0000, size: 0x0000c000, part: 0
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
R0_RxClkDly_Margin==94 ps 8
R0_TxDqDly_Margi==106 ps 9
R1_RxClkDly_Margin==0 ps 0
R1_TxDqDly_Margi==0 ps 0
dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0001
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 2048MB
DMC_DDR_CTRL: 00600024DDR size: 3928MB
cs0 DataBus test pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBus test pass
pre test bdlr_100_average==420 bdlr_100_min==420 bdlr_100_max==420 bdlr_100_cur==420
aft test bdlr_100_average==420 bdlr_100_min==420 bdlr_100_max==420 bdlr_100_cur==420
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 420
result report
boot times 5Enable ddr reg access
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x0003c200, des: 0x0172c000, size: 0x00094c00, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
E30HDR
MVN_1=0x00000000
MVN_2=0x00000000
[Image: g12b_v1.1.3375-8f9c8a7 2019-01-24 10:44:46 guotai.shen@droid11-sz]
OPS=0x40
ring efuse init
chipver efuse init
29 0a 40 00 01 20 23 00 00 04 38 34 48 56 4d 50
[3.464670 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE: BL31: v1.3(release):ab8811b
NOTICE: BL31: Built : 15:03:31, Feb 12 2019
NOTICE: BL31: G12A normal boot!
NOTICE: BL31: BL33 decompress pass
ERROR: Error initializing runtime service opteed_fast
U-Boot 2015.01 (Feb 21 2021 - 00:22:39)
DRAM: 3.5 GiB
Relocation Offset is: d6ef7000
spi_post_bind(spifc): req_seq = 0
register usb cfg[0][1] = 00000000d7f85708
MMC: aml_priv->desc_buf = 0x00000000d3ee77c0
aml_priv->desc_buf = 0x00000000d3ee9b00
SDIO Port B: 0, SDIO Port C: 1
Using default environment
In: serial
Out: serial
Err: serial
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: driver version: v20190313
vpu: detect chip type: 9
vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz)
vpu: clk_level = 7
vpu: vpu_power_on
vpu: set_vpu_clk
vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
vpu: set_vpu_clk finish
vpu: vpu_module_init_config
vpp: vpp_init
vpp: g12a/b osd1 matrix rgb2yuv ..............
vpp: g12a/b osd2 matrix rgb2yuv..............
vpp: g12a/b osd3 matrix rgb2yuv..............
cvbs: cpuid:0x29
cvbs_config_hdmipll_g12a
cvbs_set_vid2_clk
co-phase 0x3, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
co-phase 0x1, tx-dly 0, clock 40000000
aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x12000
[mmc_startup] mmc refix success
[mmc_init] mmc init success
reading boot-logo-1080.bmp.gz
27036 bytes read in 4 ms (6.4 MiB/s)
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]set initrd_high: 0x3d800000
[OSD]fb_addr for logo: 0x3d800000
[OSD]VPP_OFIFO_SIZE:0xfff01fff
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=5760, height=2160
cvbs: outputmode[1080p60hz] is invalid
vpp: vpp_matrix_update: 2
set hdmitx VIC = 16
config HPLL = 5940000 frac_rate = 1
HPLL: 0x3b3a04f7
HPLL: 0x1b3a04f7
HPLLv1: 0xdb3a04f7
config HPLL done
j = 6 vid_clk_div = 1
hdmitx phy setting done
hdmitx: set enc for VIC: 16
enc_vpu_bridge_reset[1319]
rx version is 2.0 div=10
set hdmitx VIC = 16
HPLL: 0x3b3a04f7
HPLL: 0x1b3a04f7
HPLLv1: 0xdb3a04f7
config HPLL done
[OSD]osd_hw.free_dst_data: 0,1919,0,1079
Net: dwmac.ff3f0000
Hit Enter or space or Ctrl+C key to stop autoboot -- : 0
card out
** Bad device mmc 0 **
reading boot.ini
2479 bytes read in 2 ms (1.2 MiB/s)
## Executing script at 01080000
reading resolution.ini
115 bytes read in 3 ms (37.1 KiB/s)
reading config.ini
4517 bytes read in 3 ms (1.4 MiB/s)
reading kernel.img
21473280 bytes read in 592 ms (34.6 MiB/s)
reading dtb.img
143360 bytes read in 7 ms (19.5 MiB/s)
## Booting Android Image at 0x01080000 ...
reloc_addr =d3f02500
copy done
No androidboot.dtbo_idx configuredactive_slot is <NULL>
Unknown command 'store' - try 'help'
No dtbo patitions found
load dtb from 0x1000000 ......
Amlogic multi-dtb tool
Multi dtb detected
cpu_id.chip_rev: a
Multi dtb tool version: v2 .
Support 2 dtbs.
aml_dt soc: g12b platform: w400 variant: a
dtb 0 soc: g12b plat: w400 vari: c
dtb 1 soc: g12b plat: w400 vari: a
Find match dtb: 1
No valid dtbo image found
Bad Linux ARM64 Image magic!
ee_gate_off ...
reloc_addr =d537cd10
copy done
Multi dtb detected
cpu_id.chip_rev: a
Support 2 dtbs.
Find match dtb: 1
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x02c9d008
reserving fdt memory region: addr=1012000 size=11000
Loading Ramdisk to 3cea1000, end 3d7ff200 ... OK
Loading Device Tree to 00000000d3ed1000, end 00000000d3ee4fff ... OK
Starting kernel ...
uboot time: 7001368 us
[ 0.000000@0] 07400000 - 07500000, 1024 KB, ramoops@0x07400000
[ 0.000000@0] 05000000 - 05400000, 4096 KB, linux,secmon
[ 0.000000@0] 77800000 - 78000000, 8192 KB, linux,meson-fb
[ 0.000000@0] e5800000 - ed800000, 131072 KB, linux,ion-dev
[ 0.000000@0] e3000000 - e5800000, 40960 KB, linux,di_cma
[ 0.000000@0] e3000000 - e3000000, 0 KB, linux,ppmgr
[ 0.000000@0] c0800000 - d3c00000, 315392 KB, linux,codec_mm_cma
[ 0.000000@0] e3000000 - e3000000, 0 KB, linux,codec_mm_reserved
[ 0.000000@0] e2000000 - e3000000, 16384 KB, linux,galcore
[ 0.322367@0] codec_mm_module_init
[ 0.329248@0] clkmsr ffd18004.meson_clk_msr: failed to get msr ring reg0
[ 0.344066@0] cvbs_out: chrdev devno 264241152 for disp
[ 0.558210@5] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.565130@5] meson_cpufreq_init:don't find the node <dynamic_gp1_clk>
[ 0.567175@5] meson_cpufreq_init:don't find the node <dynamic_gp1_clk>
[ 0.569125@5] ff803000.serial: clock gate not found
[ 0.665511@5] efuse efuse: open efuse clk gate error!!
[ 0.667347@5] amvideocap_probe,amvideocap
[ 0.669089@5] use cma buf.
[ 0.676329@5] di_get_vpu_clkb: get clk vpu error.
[ 0.677461@5] Reserved memory: failed to init DMA memory pool at 0x00000000e3000000, size 0 MiB
[ 0.686621@5] meson-mmc: >>>>>>>>hostbase ffffff8008595000, dmode
[ 0.737353@2] meson-mmc: >>>>>>>>hostbase ffffff800859e000, dmode
[ 0.779018@0] cectx ff80023c.aocec: cec driver date:2020/03/16:reduece no msg in sleep time
[ 0.779018@0]
[ 0.783723@0] cectx ff80023c.aocec: compatible:amlogic, aocec-g12a
[ 0.789663@0] cectx ff80023c.aocec: cecb_ver:0x1
[ 0.794216@0] cectx ff80023c.aocec: line_reg:0x1
[ 0.798759@0] cectx ff80023c.aocec: line_bit:0x3
[ 0.803335@0] cectx ff80023c.aocec: ee_to_ao:0x1
[ 0.808133@2] cectx ff80023c.aocec: not find 'port_num'
[ 0.813144@2] cectx ff80023c.aocec: using cec:1
[ 0.817641@2] cectx ff80023c.aocec: no hdmirx regs
[ 0.822396@2] cectx ff80023c.aocec: no hhi regs
[ 0.826904@2] cectx ff80023c.aocec: not find 'arc_port_mask'
[ 0.832537@2] cectx ff80023c.aocec: not find 'output'
[ 0.838931@2] cectx ff80023c.aocec: wakeup_reason:0x0
[ 0.842653@2] cectx ff80023c.aocec: cev val1: 0x0;val2: 0x0
[ 0.848137@2] cectx ff80023c.aocec: aml_cec_probe success end
[ 0.856100@2] defendkey ff630218.defendkey: Reserved memory is not enough!
pwr_key=23dc4db2
usr_ir_proto = 00000000
pwr_key_mask = ffffffff
system power = 00000000
[ 0.879992@2] asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
[ 0.882128@2] snd_tdm ff642000.audiobus:i2s2hdmi: ASoC: Failed to add I2SIn CLK: -16
[ 0.889832@2] aml_dai_tdm_probe, failed add snd tdm controls
[ 1.048405@3] thermal thermal_zone0: binding zone soc_thermal with cdev thermal-cpufreq-0 failed:-22
[ 1.051960@3] thermal thermal_zone0: binding zone soc_thermal with cdev thermal-cpufreq-1 failed:-22
[ 1.061323@3] pm-meson pm: Can't get switch_clk81
[ 1.260846@1] meson-fb meson-fb: create ion_client ffffffc0db570b40, handle=ffffffc0dba7b8c0
[ 1.263672@1] meson-fb meson-fb: ion memory(0): created fb at 0x00000000e5800000, size 75 MiB
[ 1.301330@3] meson-fb meson-fb: create ion_client ffffffc0db570b40, handle=ffffffc0db69a080
[ 1.304129@3] meson-fb meson-fb: ion memory(1): created fb at 0x00000000ea400000, size 1 MiB
CoreELEC:~ # wake-on-lan = 00000000
this was: i rebooted CE and i got a first short signal (coreelec logo) and then the TV did not receive any further signal
