looks like it’s still supported:
But the “now” is missing:
The problem is this commit does not apply anymore on new kernel and need to be reworked.
Tvheadend - No available adapters
http://ix.io/3MsC
ps. Last working build for dvb crazy cat driver
CoreELEC (official): 19.4-Matrix_nightly_20220110 (Amlogic-ng.arm)
CoreELEC:~ # dmesg|paste
http://ix.io/3Mt3
CoreELEC:~ #
Are you sure you’ve tried today’s nightly? We had a problem in latest releases that was fixed today
But you can see number build into log, this log from today build RC2, but today nightly the same history
Can you check your crazycat addon version?
I install rc2 and tvheadend show no available adapter, after this I’m reinstall add-on and tried all have driver, and add-on see installed driver, but tvheadend not see any adapter
Thanks Coreelec team, Coreelec-19.4-Matrix_rc2 works well. Works on DVB drives.
I have serious audio to video sync issues with the nightlies, almost to the point of unusability. If you pause the playback it usually brings them back into line for a while but syncing doesn’t become perfect.
Is anyone else experiencing sync issues with this kernel ?
Long time the Fashion UHD TV on Hotbird is not showing broadcast. Channel Broadcast FTA. What could be the reason?
Wetekplay 2 and Beelink King Pro do not show on both devices.
Beelink log
http://ix.io/3Mz4
Please upload debug log after reboot and playing this stream
May be unsupported frame rate for 4K H264
I thought you were encrypting before. I thought you were encrypting before.
after reboot
http://ix.io/3MA9
It’s only dmesg log and I don’t see for any stream playback
See the link in my previous message how to collect debug log.
In case it’s encrypted you will see black screen in most cases.
Log files
http://ix.io/3MAt
Yes ,I met the sync issues too,It seems to happen on N2 only, on vim3 ,no issues, don’t know why.
I don’t see something that tries to recognize this channel format
but there are some errors that I don’t know what they mean.
2022-01-17 20:20:42.359 T:3964 DEBUG <general>: ffmpeg[(nil)X]: [image2] Custom AVIOContext makes no sense and will be ignored with AVFMT_NOFILE format.
Jan 17 20:20:43.932484 CoreELEC tvheadend[3300]: diseqc: failed to set high voltage 0 (e=Unknown error 524)
You could also try to enable ffmpeg option additionally in debug components. Use latest nightly. May be some stream details will be visible if it receive something.
Please reboot box and enable debug with audio/video sync enabled
Just after issue will be repeated stop debug and upload debug log
Also please clarify what are you using as audio output?
@crazyturk please try today’s nightly again. Your log still shows errors what should have been fixed with nightly 20220118
The daily receiving link over the device gives an error.
file log 18-01-2022
https://paste.c-net.org/DoughAngels
Do you mean error for channel we talked about?
You have a G12B rev a SoC, please try this in SSH:
mount -o rw,remount /flash
fdtput -t x /flash/dtb.img /reserved-memory/linux,di_cma size 0 5800000
sync
reboot
Also try to limit HDMI output to 4:2:2 in Kodi settings, thx.
@startv @Shoog Please try this SSH cmds also on your hardware. I have seen this also on my device, video starts stuttering and play normally after 1-2 seconds, audio start normal. So they are finally out of sync. Pressing pause bring them back in sync as audio stops and video continue running until they are in sync again.
