Will try that and report back.
Edit: Initial impressions are good.
@Shoog @startv please pick your dtb from here and update dtb.img by your needed one:
Please report if the video/audio sync error is fixed. Thx!
There seems to be also a bug when you pause/play video few time sound is going out of sync by few ms - when you stop playing and play this file gain all is the same way it should be.
I use nightly build on X96 Max plus 4/64 installed on emmc.
Movie played from USB 3.0 HDD.
How to update dtb.img that is on emmc(flash folder i assume?) Canât copy to this folder over ftp.
I tried with nightly(newly downloaded from www)+new dtb.img from mega(didnât try the one with img) and it is ok now from sd card - will try to update it on emmc now.
From emmc is ok as well.
N2 replaced the old dtb.img with the new one , the video/audio sync error is fixed, thank you .
Emmc or sd boot? It looks like it is back after a while on my box.
n2 boot from sd card
your box is sm1(s905x3), it should already have this fixâŚ
I think a clean install with no addons will solve the issueâŚ
Will check it on friday - you might be right as on sd card it was a clean install while on emmc i did update - unless it removes everything as well first?
Hi guys, sorry and what now Nexus not will new builds?
CoreELEC-Amlogic-ng.arm-20.0-Nexus_nightly_20220113.tar this is last
Weâre working on it!
Build 20220120 is available.
tonight will test
ps.
KI PRO
CoreELEC (official): 20.0-Nexus_nightly_20220120 (Amlogic-ng.arm)CoreELEC:~ # dmesg|paste
http://ix.io/3MVA
X96Max
CoreELEC (official): 20.0-Nexus_nightly_20220120 (Amlogic-ng.arm)CoreELEC:~ # dmesg|paste http://ix.io/3MVG
X96Max+2_AI
http://ix.io/3MVL
All is working, great work, youâre best guys
Has anyone noticed a problem with the PlayerProcess VideoDAR with the nightly builds after the kernel bump?
H.265 content using the AMLogic decoder always indicates a video aspect ratio of 0.25
Aspect ratio is correct for H.264 content or if software decoder is used
The initial decoder info is correct, but after that the aspect ratio value is always 0.25
CAMLCodec::OpenDecoder hints.width(1920), hints.height(800), hints.codec(173), hints.codec_tag(0)
CAMLCodec::OpenDecoder hints.fpsrate(24000), hints.fpsscale(1001), video_rate(4004)
CAMLCodec::OpenDecoder hints.aspect(2.400000), video_ratio.num(1), video_ratio.den(1)
CAMLCodec::OpenDecoder hints.orientation(0), hints.forced_aspect(1), hints.extrasize(86)
AAC decoding doesnât seem to be working in the nightlies.
Hi everyone,
I am on N2+ 4G and updated to the latest nightly but I cannot get any playback at all.
I have a black screen and it takes ages to launch the player after I clicked on a movie. It used to work smoothly before so I donât understand whatâs happening and wanted to provide feedback.
I created a log (my first one) so hopefully it can help:
http://ix.io/3MW2
Jan 20 19:32:44.161425 CoreELEC kernel: check sum fail !
Could you try to update to same version again?
Out of curiosity: what exactly is the gain with the new kernel ?
