@Sholander we have been waiting for the LE guys to make a release so anything we put out there is at equal parity with them.
Nightly contains 18.2 obviously.
I know, but mandatory updates are annoying for my parents
But why do your parents need Kodi 18.2?
Only on 18.2 with inputstream.adaptive 17.1 HBO-Go EU works flawlessly with subtitles
All other combinations have occasional problems on their Mecool KM8 box.
Fair enough.
Thatās good to hear. Iāve had some bad experiences in the past with forced updates. Generally I disable them on any product if a hack is possible.
I can understand and accept a forced update policy with the nightlies, but Iāll be looking forward to getting off them as soon as the ng release becomes stable.
Iām having a repeat of the same issue from Nightly builds - #615 by kostaman
Iām on the Nightly_20190508 which i manually updated to.
Mine downloaded and updated fine on 0508
I am also having the auto update problem from Nightly_20190508 which I manually updated to.
I receive an update notification but the build does not download.
Same as skewers⦠get annoying update notifications⦠So did a manual updateā¦
All is good now
I was just about to post about the lack of download of the 0509 nightly, but Skewers beat me to it.
EDIT: I should note that if I switch to manual, it doesnāt show up as an available download either. Branch doesnāt indicate nightly, just āCoreELEC-9.0ā (not sure if nightlies mention branch regardless).
The update issue is now fixed for the next update.
If youāre using Nightly_20190508 .
Toggle to Manual and Reboot.
After reboot donāt forget to toggle back to Auto.
Youāll get a notification of update available followed by download complete.
Reboot and all will be good.
Otherwise just Manually download .tar
Thank you ⦠I did the manual / auto toggle and all went well.
Nightly_20190509 would not auto update to Nightly_20190510 for me without using the manual / auto toggle method.
Installing Nightly_20190510
Should have Auto Update fixed for next update.
Iāve got an odd issue Iāve been encountering with system time being wrong, then correct, then randomly wrong again. Today itās 40 minutes out which is very odd. I have the Timezone set correctly so not sure whatās up. Anyway, not a big issue just weird. Running latest nightly on Le Potato.
For me after Nightly_20190510 remote is not working.
Update: Solved by restart.
Auto update is now working properly again.
Thank You
In the nightly build 20190512 the * [kodi/amlogic-ng: workaround for VC1 progressive (afl1)] is broken.
Can it be adjusted? Thanks.
How is it broken?
