Thanks to a user’s contribution, we now have LPCM support in the 4.9 kernel (Amlogic-ng).
Everything has been pushed, and should be available in the next nightly build. (20190929)
We were able to test it on Odroid N2 and Beelink GT-King. We have not tested it on S905X2 devices, but it should work. Please report any issues with this new feature.
Configuration:
Disable the Enable Dolby Digital (AC3) transcoding option under Audio Passthrough
Select the HDMI Multi Ch PCM option in Audio output device
Select the number of channels
Leave other passthrough settings as they are, the passthrough device should remain HDMI
If some of you are not sure about which audio settings to use, take a look at Kodi’s Audio quick-start guide Especially for those of you with an AVR should select number of channels to 7.1 (regardless of your sound setup - example 5.1)
Use the maximum number of channels (7.1) then the AVR will convert it to 5.1 so it will always be of good quality. Let the AVR do its job, it will do better.
Updated the last night. Work on a mkv archives, but without sound in a VOD platforms (Netflix and HBO).
Odroid N2.
Am I the only one who happens to or happens to any of you?
Latest Nightly: 7.1 Lpcm working fine, in my Beelink GT-King.
Atmos and DTS-X working as before in my mkv’s
Netflix : Atmos , True-HD working as before.
All working fine.
I’m a bit perplexed. On the LePotato multichannel has been working fine (aac, flac and pcm 5.1 and 7.1). With this latest nightly it is still working just fine . . . Was it not supposed to work before?
New sound features.
S905X2
Had to turn off HDMI muliti channel pcm as no sound.
Using normal HDMI setting
Also some movie and movie tracks dont play properly with 7.1 Bad stutter.
Back to 2.0 on my AVR 5.1 setups. (x2)
Still getting all channels played as required so not a big issue.
Dolby channel test file shows OK.
As the title says, recently I’ve been having a lot of lock ups, mainly when scrolling thro large lists. For example,when looking thro all TV channels in order to add one to a group in PVR group manager. I’ve also had it when scrolling thro artists in my music library, when an attempt to play something causes the lock up.
I can SSH a reboot command but it takes ages to execute if at all. In some cases I’ve pulled the plug and restarted that way.
