I’ve added a power/wake button to the new C4, the same as I’ve done with my previous N2’s. Using the button it to power down works fine, but wake does not work.
I’ve edited the config.ini, added:
gpiopower=479 # (pin 11)
The same as I’ve always done with my Odroid N2’s. But wake/power-on will not work with the button. I have even held the button down for several seconds, up to 10 seconds, with no luck. HardKernel wiki says that somethimes several seconds is required.
I have no problem waking device with the IR remote.
Has anyone else added a wake button to their C4? If so, do you have the same issue, or does yours work as expected? Have I missed/forgotten a step to get this to work?
They all will put the board to sleep (except one), none will wake the device:
gpiopower=476 # (J2 pin 16, to of pin 14 GND)
gpiopower=479 # (J2 pin 11, to pin 9 GND)
gpiopower=490 # (J2 pin 29, to pin 30 GND)
gpiopower=489 # (J2 pin 10, to pin 9 GND)
gpiopower=487 # (J2 pin 23, to pin 25 GND)
This last pin test didn’t work for sleep or wake:
gpiopower=481 # (J2 pin 33, to pin 34 GND) Doesn’t Work on these pins!
I updated the config.ini file accordingly each time and rebooted. So the wake button not working issue I’m experiencing, isn’t just due to the J2 pin I was using initially.
Are there pull up for the gpios?
The bootloader is checking for a change of the logic level. So if it is already low a connection to GND will not trigger a wake up. Did you try to connect a pin to +V instead GND? I will check it tomorrow on the C4.
Yes, there is a working builtin pull-up resistor on the pin 11 that I’m using, I’ve checked with DVM. When the board is in sleep mode, there is 3V on GPIO pin 11. Which gets pulled to ground when button is pushed, and then returns to 3V.
