You can configure in tvheadend the recording destination and yes, you need more than one to watch one channel and record another (if they are in different muxes).
Thank you for help guys, for my single lnb setup you convinced me to use internal tuners instead of usb ones
@afl1 You recommend Khadas as the best board. Is it only because of ease of installation (7 cables). Or does the external power supply influence performance as well?
From the images I see that Mecool requires external AA batteries and WP2 tuner doesn’t?
You can read the topic and decide for yourself (afl1 is on vacation). I have a vtv (use it for dvb-c though) and it’s a quality board as you could expect from Khadas. The site you mentioned I think is trustworthy and the price is the best you can find outside special promotions (even then it’s a very good price). You can see it’s cheaper than bought directly in Khadas site or AliExpress store.
I have a tuner wetek play 2, and already tried to make a link like what is in a photo in this forum, can someone give me a more detailed scheme of links. Thank you
You should continue in the correct topic. Here you can find the scheme in the photos. It shows which pin is connected in both sides. You can try with female-female dupont cables. In hardkernel forum you’ll find a similar topic and try there also.
De nada. If you need more help just say. If you look closely to afl1 post he shows the pins numbers of the wetek tuner and you just have to follow the image that shows which pin connects to the gpio pins in the N2
Yes yes I tried to follow his picture but my doubt is the ams 1117 link. Since here in Portugal was difficult to find this current transformer. Either I don’t understand the scheme, or I have the connections switched, because in the N2 gimp everything is fine.
Obrigado na mesma,
Abraço
But did you find it? I think the scheme is pretty straight forward the only question, as you say, is the pins in the tension regulator. You have to connect one to the 3.3v pin in the N2, gnd/gnd and the 1.2v pin to the pin nr 12 in the wp tuner. Can’t you go to the electronic shop where you bought it and they can point out the correct pins in the regulator?
