@afl1
Is it possible wetek WP2 internal DVB tuners on Android OS work like Coreelec OS with wp2 tuner android driver ?
wetekdvb_android_driver.zip (182 Bytes)
@afl1
Yay! Success:
CoreELEC:~ # dmesg | grep dvb
[ 0.000000@0] CoreELEC dt-id: g12b_s922x_odroid_n2_dvb
[ 2.934169@0] kernel-overlays-setup: processing conf /storage/.cache/kernel-overlays/50-driver.dvb.dvb-latest.conf
[ 2.969591@0] kernel-overlays-setup: added modules from /usr/lib/kernel-overlays/driver.dvb.dvb-latest/lib/modules/4.9.113
[ 12.363120@0] dvb_meson dvb: Found i2c-2 adapter: Meson I2C adapter
[ 12.363128@0] dvb_meson dvb: ts0: serial s2p0
[ 12.363255@0] dvb_meson dvb: ts0_control: 0x0
[ 12.363259@0] dvb_meson dvb: ts0_invert: 0x0
[ 12.363330@0] dvb_meson dvb: dev_name=avl6862
[ 13.578459@0] dvb_meson dvb: DVB demod detection for i2c-2 (Meson I2C adapter)…
[ 14.794447@3] dvb_meson dvb: Checking for Availink AVL6862 DVB-S2/T2/C demod …
[ 14.794951@3] i2c i2c-2: dvb_meson: found AVL6862 family_id=0x68624955
[ 16.333495@0] i2c i2c-2: dvb_meson: Rafael R912 successfully attached!
[ 16.333504@0] dvb_meson dvb: Total DVB modules found: 1
[ 16.343128@0] dvbdev: DVB: registering new adapter (dvb_meson)
[ 16.352368@4] dvb_meson dvb: DVB: registering adapter 0 frontend 0 (Availink avl6862)…
Still need to buy the cable to hook up the antenna, but the tuner works.
Thanks for the help guys.
good day,
please help advice:
it is possible - Mecool K-series internal DVB tuner
to connect to Odroid C4? Described PIN https://wiki.odroid.com/odroid-n2/hardware/expansion_connectors same.
I have connected but it does not work.
I do not understand where, how ?: g12b_a311d_odroid_n2_dvb.dtb
@Vasco is working on a DVB dtb similar to the N2 one specific to Odroid C4.
probably something wrong
I’m trying
DVB drives for TBS (Crazycats)
DVD drivers from the latest kernel(media_build)
I understand
@Vasco builds! It doesn’t work on C4 yet
You understand I Ray. It will work.
please, give me an advice:
in the night set there is already dtb: sm1_s905x3_odroid_c4_dvb.dtb.
Involved C4 a
Mecool K-series internal DVB tuner board, Tvheadend 4.2 or 4.3 all drivers.
success! I see active
Availink avl6862 # 0: DVB-T # 0,
DVB-C, DVB-S
I do a scan of the preset muxe and the exact frequency. Unfortunately SCAN RESULT - FAIL.
When scan so Tvheadend -
DVB-T Status - SNR 100% - Signal Strength 81%.
DVB-S same: SNR 0% - Signal Strength 100%
Do you have the TV Adapters - Tuners associated with the correct Networks?
Yes, I definitely have DVB-T and S assigned to the correct networks. I try it both automatically during installation and manually the same.
DVB-T and others glow green and nothing.
thank you for every idea
Out of curiosity try disabling the dvb-s in tvh and scanning the dvb-t. There is a full spectrum scan option for dvb-t which is the one to use.
Yes, I’m trying too. Furthermore:
DVB-T antenna connected DVB-S disconnected and vice versa.
Now I have tried coreelec 9.2.3 still the same.
But I can see the boards scan FAIL.
Another power supply 12V 2.5A.
I have two, Mecool K-series internal DVB tuners work the same.
I install the VDR, DVB-T scan DVB-S does not find anything, it sees the board.
Have you tried both modules? Crazycat and dvb latest?
Thank you for your help.
I give up. Tvheadend sees the record.
Unfortunately scan - FAIL.
I suspect:
Khadas VTV board
or usb TBS5520SE?
Hi I use the TBS box with CoreELEC without any issue. Just need to use the Crazycat drivers. It’s runs both DVB-S and DVB-T but you can only run a single service at a time. I also use an Xbox DVB-T tuner so I can watch on 2 devices at the same time. One issue I had with the N2 was the USB 3 ports that didn’t work with the TBS box so I used a OTG adaptor in the front port and supplied power to the box via a powered USB hub.
Beware that the Xbox One USB DVB-T/T2 tuner is known to be problematic for some broadcasts. It’s very low cost, but not always a perfect solution.
ATTENTION:
my experience.
Are the 52 services DVB-T or DVB-T2? The Xbox One tuner appears to be more problematic for T2 than T.
I use the TBS5520SE with Beelink GT King Pro.No problem.
