just tried your release, the screen upside down, I modified the vfd.conf from vfd_display_type=‘0x1F,0x3C,0x00,0xFD’ to vfd_display_type=‘0x1F,0x3C,0x08,0xFD’,no change
this is my vfd.conf
vfd_gpio_clk=‘0,0,0xFF’
vfd_gpio_dat=‘0,0,0xFF’
vfd_gpio_stb=‘0,0,0xFF’
vfd_chars=‘0,1,2,3,4’
vfd_dot_bits=‘0,1,2,3,4,5,6’
roidy
11 May 2019 10:54
79
My addon has absolutely nothing to do with OpenVFD or any vfd.conf files…
I created this thread to discuss my addon Odorid N2 Oled Driver but it seems to have been taken over by OpenVFD talk
I will add an option to flip the screen for those users who have installed their Oled’s upside down
also some bugs
I have disabled openvfd addon
You’re absolutely right, and I apologize. I split the discussion of OpenVFD to its own topic.
roidy
11 May 2019 11:09
82
What screen size is that and what chipset is it, SSD1306 or SH1106?
Have you opened the the addons settings and selected the correct screen size and chipset?
roidy
11 May 2019 11:11
83
Much appreciated, I’d only get lost not knowing weather people where having problems with my addon or OpenVFD
Does 128x32 oled shows flag icons when playing? in my case, no icons
roidy
11 May 2019 11:42
86
No icons on the 128x32. The screen is just too small to fit them.
I’m working on a flip fix, I’ll post an updated version soon.
roidy
11 May 2019 12:05
87
Version 0.1.1 is now up and includes the ability to flip the display. Give it a try.
roidy
11 May 2019 12:30
89
Have you tried it yet?
Does it work ok?
What type/size displays do you have?
In service.py, aac is declared 2 times (lines 15 and 20).
roidy
11 May 2019 12:35
91
Well spotted
Not a breaking bug… but a bug non the less, I’ll fix it the next update I do, Thanks.
Awesome work @roidy I have one of these displays and will try this later.
Not tried yet. Will solder on Monday a 128x32 SSD1306.
roidy
11 May 2019 15:15
95
Are you still getting the corrupted display issues you posted the images of?
yes, v0.1.1 did not fix it
@roidy you should be able to easily reproduce this if you have a SSD1306 128x64 oled, or even SH1106.
You can run these in 128x32 mode.
