Odroid N2 OLED I2C / SPI driver
Not sure what the issue is, I’ve got a lot of these little oled displays from various sellers and I’ve tried a few of each size and controller type and they all work perfectly.
@startv Do you have a link to the oled you purchased please.
Hello @roidy, great work. Can you give an option to replace the playback time with current local time or the media icons for smaller displays? Thanks.
@startv Could you give this version a try please:-
Version removed
Maybe in the future, I’ll like each line to be user selectable.
can you add k1 pro hw i2c ssd1306.
Tried, but no change
I found the issue caused by vfd.conf, I deleted it and reboot, the time shows OK.
It should just work, because he’s using I2C #2, same as on the KI PRO.
Ok I tested that works on k1pro :slight_smile:
That’s great. Could you modify a vfd.conf file suit for your addon?
You only need vfd.conf for OpenVFD. @roidy’s driver is completely unrelated to OpenVFD.
Good to hear, I make a note that vfd.conf needs to be removed.
whats pins are these being connected to?
Matt
Everything is in the read me file on github.
README
Thanks, dunno why I didn’t think of looking there.
Matt
Works perfectly here, N2 and 128x32 SSD1306.
Thanks very much, this is just great!!
Perfectly :slight_smile:
Lol… I was wondering if anybody had one of those two color displays and if my icons would line up correctly with the top color. Looks like I guessed the position right :smiley:
