My N2 w/i EMMC was delivered yday and, first impressions, it’s very quick!. Almost on par with my old Wintel i5 kodi platform (which i gave up on for various reasons).
It’s definitely quicker than my Vero 4K+ (which is decent tbf) but the N2 has extra zip particularly running the heavt Titan MOD skin.
Also, confirmed that the N2/CE passes HDR MaxFLL & MaxCLL metadata (pending for the Vero) so tone mapping now works and matches my Oppo.
However, one thing is that the N2 does run quite hot - which is fine when it’s being used but bit of a waste when not. The Vero has a CEC Suspend function which lowers CPU etc so it runs pretty cool when the TV is off. On N2/CE the Suspend mode switches off the device. Hibernate option doesnt do anything.
Any chance CE can support CEC Suspend like the Vero?
I’ve just made a test for you. CEC suspend and wake up works fine.
My setup is N2 - Denon AVR X2600 - LG tv
Why do you think your N2 shuts down?
Or what is the problem with it if it wakes up through CEC or IR command or WOL or power button?
copy sample file and rename it to sleep.conf (placed here: \IP\Configfiles\sleep.conf.sample)
edit it and delete string SuspendMode=false, save it and reboot and try again if it works.
