Odroid N2 test builds
Using the nightly from july 1st, for the first time, my flirc will consistently disconnect / become unresponsive. Unplugging all my usb devices and plugging the flirc back in does not yield any fix. The only way to fix it Is to reboot the device. If I wait about 20 minutes or so (of inactivity) my flirc will again become unresponsive. There was absolutely no issue what so ever with my flirc until the last two nighties.
Any ideas? Could the usb ports have gone into a sleep state?
Thanks!
EDIT: I Think it may have been just low batteries after all … doh
The stable version didn’t work for me. Hangs at CoreELEC logo screen and stays. Rewritting eMMC card.
Sorry about that found a last minute problem with the website pointing to the wrong files. should be fixed soon.
For anybody wanting to switch to the new stable build from the nightly, the update file is https://github.com/CoreELEC/CoreELEC/releases/download/9.0.3/CoreELEC-Amlogic-ng.arm-9.0.3.tar
The stable build is a good option for anyone not comfortable with frequent updates to development builds.
For those who like living on the edge and help testing and providing feedback on the most recent developments, the nightly builds will continue as before.
Were there any USB related updates performed lately ?
I have serveral tv tuners, and some of them stop working (sundtek) after a short while with the following error in the kernel log:
Blockquote
usb 1-1.1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 192 rq 6 len 1 ret -71
Until I restart the odroid, it won’t tune to the correct frequency.
It used to work correctly with older builds…
The update option for Amlogic-ng is also included in the download helper on our website, now.
I saw this errors several times when not connected to the OTG USB port. I’m on the latest nightly and it still works for me.
Well, I cannot use the otg, as I have 4 tuners :frowning:
Maybe you can use a USB hub and power the tuners externally. I do only have one tuner and it is plugged there. I had this problems before. There were several kernel updates recently but it seems the issue is still not solved. There are discussions ongoing in the odroid forum, however, I don’t know about a final solution.
I do have a second N2 running Ubuntu and it does random restarts caused by heavy load and kernel panics I suppose. There is also a discussion ongoing about that. However, no solution neither.
just to confirm i do exactly this, 4 x dvb-t2 tuners (xbox tv tuners) running off usb 3.0 4 port powered hub, works great :-).
Is there a tracker issue, or forum discussion on the Hard Kernel site for those of us interested in tracking the status of the multichannel PCM implementation? I couldn’t fine one.
No. This is being worked on but there is nothing public what the status is.
@Ray I heard from @tobetter about a possible fix of the USB issue. As far as I understood there were updates applied to the kernel and uboot. Could you bring this (latest kernel and uboot) to Coreelec?
I’m not sure if it works but I guess it is worth a try.
https://forum.odroid.com/viewtopic.php?f=181&t=34849&start=50#p261376
I supposed to share the patch after having some report from a user and after Petitboot update. But, yes…definitely worth to try to see if it works for others as well.
EDIT:
The patches for U-boot and Kernel pushed and hope they can mitigate the issues and Petitboot update is also uploaded just now.
https://forum.odroid.com/viewtopic.php?f=182&t=33873&p=261451#p261451
Tobetter pushed it. Just need to update the packages and it might be in tomorrow’s Nightly
Since you mentioned you have 2nd ODROID-N2 running Ubuntu, you would be able to update it. Please do sudo apt update and sudo apt upgrade before rebooting.
I updated it accordingly to your description in the odroid forum. sudo is not required for me since I’m logged in as root. I added the command in the boot.ini as described.
By the way @tobetter, I face random restarts on the N2 running Ubuntu. It might be caused by kernel panics during heavy load as some users suggest at the odroid forum. Any help for this issue? I don’t see it happening for Coreelec.
Thanks @Ray for helping so quickly.
Hi @tobetter , I have read above that there is a uboot update.
I wonder if you have also fixed the problem that @anon88919003 was writing about: ā€žsometimes the device halts on rebootā€
It happens quite often with my device.
No this is investigate.
This ā€œhalt on power onā€ is known and I am searching for reason. Some module freeze the kernel on booting. Sometimes every second boot, sometimes every 1 of 100 boots.
Use suspend mode instead of power off until this issue got fixed, this is now the work around :wink:
